hi!
i hat a funktion to clear all layers in fdo-explorer. current when a display model is loaded:
my function delete all layers and groups in 2019
Public Function RemoveAllFdoLayers(Optional ByVal Silent As Boolean = False, Optional ByRef LogText As String = "") As Integer
' ------ https://forums.autodesk.com/t5/autocad-map-3d-developer/remove-special-or-all-layer-by-topobase/m-p/7243854#M5015 ------
Dim CountOfLayers As Integer = -1
Dim CountOfGroups As Integer = -1
Dim MsgCurrentMapDefine As String = "undefine"
Try
Dim docLock As DocumentLock = _AcDocument.LockDocument
Using docLock
Dim currentMap As Autodesk.Gis.Map.Platform.AcMapMap = Autodesk.Gis.Map.Platform.AcMapMap.GetCurrentMap()
Dim layers As OSGeo.MapGuide.MgLayerCollection = currentMap.GetLayers()
If Not IsNothing(currentMap) Then
MsgCurrentMapDefine = "define"
CountOfLayers = layers.Count
CountOfGroups = currentMap.GetLayerGroups.Count
currentMap.GetLayers().Clear()
currentMap.GetLayerGroups().Clear()
End Using
Catch ex As System.Exception
Dim Msg As String = "unerwarteter Fehler in EBL.Layer > Layer_DisplayModell > RemoveAllFdoLayers" & vbCrLf &
"CountOfLayers:= " & CountOfLayers.ToString & vbCrLf &
"CountOfGroups:= " & CountOfGroups.ToString & vbCrLf &
"MsgCurrentMapDefine:= " & MsgCurrentMapDefine & vbCrLf &
ex.ToString & vbCrLf
LogText += Msg
If Silent = False Then
_TryReport.Show("unerwarteter Fehler in EBL.Layer > Layer_DisplayModell > RemoveAllFdoLayers", Msg)
Return -1
End Try
Return CountOfLayers
End Function
in 2022 the result will be
in 2019 the group "Sielkataster" will even delete.
did someone now if there will something changed?
if i now load a display modell following error will show (translate):
"error by draw the displaymodel. reason: error by draw in map - unallow arguments - it is not allow a empty draworder"
alternative i would delete the "Sielkataster" coded - but how.
if i delete "Sielkataster" manual then i could draw a new displaymodel.
regards Jan
For English version see below
Hey Jan,
konkret kann ich Dir nicht weiterhelfen. Aber zwei Dinge gehen mir durch den Kopf.
1) Gibt es zischen der 19er und der 22er Version Unterschiede beim Count ?
2) Gibt es in 22er eventuell ein Parentobjekt oder vllt. Rootobjekt jeweils zu den Gruppen ?
Ich würde mir einen Breakpoint setzen und mir die Instanzen von GetLayers() und GetLayerGroups() genauer ansehen. Vermutlich findest Du dort Hinweise bzw. Unterschiede.
Etwas OffTopic, aber denoch IMHO zu bemerken.
Statt einen Fehler abzufangen, könnte man auch eine NULL Prüfung machen. Fehler und auch deren Behandlung kosten immer sehr viel und werden üblicherweise soweit es geht vermieden. Nur wenn nicht kontrollierbare Situationen auftreten, z.B. bei Netz-Zugriffen auf DB oder Files ist es wirklich geboten oder in der GUI. Meist - gerade in Methoden, die nichts mit der GUI zu tun haben, ist es aber auch sinnvoll den Fehler passieren zu lassen. Den kannst Du ja dann eher beim Aufruf der Funktion abfangen.
English Version
Can't help you directly, but two things go through my mind.
1) Are there diffs between 22 and 19 regarding the Count ?
2) For 22 version: Is there an parent object or an root object in GetLayers() und GetLayerGroups() ?
Set a breakpoint at GetLayers() und GetLayerGroups() and maybe you'll find a difference.
Offtopic:
Maybe you try to avoid catch statements, if possible. IMHO in this case it would be enough to check for NULL. Errors are expensive in general.
Hi !
(english below)
danke für die Rückmeldung. Die 2019er Version kann ich leider nicht mehr testen, da die DB hochgezogen wurde.
Ich habe aber einmal eine Iteration durch die Gruppen vorgenommen und namentlich wird die ursprunglich angemerkte Gruppe "Sielkataster" auch gelistet wird. Das Entfernen wurde dann auch manuell durchgeführt. Bis auf die Root-Gruppe hat das auch mit dem Entfernen geklappt.
Gruß Jan
Hi !
Thanks for the feedback. Unfortunately,
I can no longer test the 2019 version because the DB has been pulled up. But I once did an iteration through the groups and the originally noted group "Sielkataster" is also listed by name.
The removal was then also carried out manually. Except for the root group, this also worked with the removal.
Greetings Jan
