Problem with reading ObjectData via AcDbDatabase
Hi all
I have Drawing (Drawing 1.dwg) with some entities and these entities has attached ObjectData. When i open new (empty) dwg file and run my code so i don't get AcMapODTable object. I need to read Column Name of ObjectData, but method pODCont->GetODTable(pODTable, record.ODTableName() return kErrObjectNotFound. I don't know how Can i get Column Name when i open my Dwg files via AcDbDatabase.
thank you all for advice Milan.
AcDbDatabase* pDatabase = new AcDbDatabase(Adesk::kFalse);
if(pDatabase->readDwgFile(L"c:\\dwgTest\\Drawing1.dwg", _SH_DENYNO)!=Acad::eOk) {
m_strErr.Format(L"I can't open the file: c:\\dwgTest\\Drawing1.dwg !");
acedPrompt(m_strErr);
Acad::ErrorStatus es;
AcDbBlockTable* pBlockTable = NULL;
AcDbBlockTableRecord* pBlockTableRecord = NULL;
es = pDatabase->getSymbolTable(pBlockTable, AcDb::kForRead);
es = pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForRead);
es = pBlockTable->close();
AcDbBlockTableRecordIterator *pIterator = NULL;
es = pBlockTableRecord->newIterator(pIterator);
for(pIterator->start(); !pIterator->done(); pIterator->step()) {
AcMap::EErrCode ec;
Adesk::Boolean AdeskBoolean;
AcMapSession *mapApi = NULL;
cMapProject *pProj = NULL;
AcMapODContainer *pODCont = NULL;
AcMapODTable *pODTable = NULL;
mapApi = AcMapGetSession();
AdeskBool = mapApi->GetProject(pProj);
AdeskBool = pProj->GetODContainer(pODCont);
AcDbObjectId eId;
AcMapODRecordIterator* pTableIterator = NULL;
ec = pODCont->GetObjectODRecordIterator(pTableIterator);
es = pIterator->getEntityId(eId);
ec = pTableIterator->Init(eId, AcMap::kOpenForRead, Adesk::kFalse);
for(; pTableIterator->IsDone() == Adesk::kFalse; pTableIterator->Next()) {
AcMapODTableRecord record;
ec = pTableIterator->GetRecord(record);
ec = pODCont->GetODTable(pODTable, record.ODTableName());
if(ec == AcMap::kOk) {
AcMapODTableDefinition TabDef;
AcMapODColumnDefinition ColDef;
TabDef = pODTable->Definition();
for(int i = 0; i<TabDef.Count(); i++) {
TabDef.GetColumn(ColDef, i);
CString ColumnName = ColDef.Name();
delete pODTable;
delete pTableIterator;
delete pIteretator;
pBlockTableRecord->Close();
delete pDatabase; Edited by: hokrm on Jun 15, 2009 8:47 AM
Did you ever find a solution to this? I'm trying to do the same thing.
Jamie
