MapiInsert using c#
MapiInsert using c#
mchan01
MapiInsert using c#
mchan01
Is there a may to user MapIInser command in c#?
I would want to use the command and automatically download an image file i create. I wanted to skip the file selection mode.
I had to replace an existing image with a new one in multiple drawings. I didn't find an "mapiinsert" function in Map API.
Here is what I used at the end:
        public static void win_imageinsert(Database openedFileDB, bool backgroundTransparent)
            Database acCurDb = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database;
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            Document curDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database acCurDb = openedFileDB;
            Editor ed = UtilCadActive.Editor;
            Document curDoc = UtilCadActive.Document;
            using (DocumentLock docLock = curDoc.LockDocument())
                using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                    // Define the name and image to use
                    string strImgName = dicImageInsertDetails["imagename"];
                    string strFileName = dicImageInsertDetails["sourcename"];
                    RasterImageDef acRasterDef;
                    bool bRasterDefCreated = false;
                    ObjectId acImgDefId;
                    // Get the image dictionary
                    ObjectId acImgDctID = RasterImageDef.GetImageDictionary(acCurDb);
                    // Check to see if the dictionary does not exist, it not then create it
                    if (acImgDctID.IsNull)
                        acImgDctID = RasterImageDef.CreateImageDictionary(acCurDb);
                    // Open the image dictionary
                    DBDictionary acImgDict = acTrans.GetObject(acImgDctID, OpenMode.ForRead) as DBDictionary;
                    // Check to see if the image definition already exists
                    if (acImgDict.Contains(strImgName))
                        acImgDefId = acImgDict.GetAt(strImgName);
                        acRasterDef = acTrans.GetObject(acImgDefId, OpenMode.ForWrite) as RasterImageDef;
                    else
                        // Create a raster image definition
                        RasterImageDef acRasterDefNew = new RasterImageDef();
                        //--> robert
                        //acRasterDefNew.ResolutionMMPerPixel = new Vector2d(312.5, 312.5);
                        //acRasterDefNew.ResolutionUnits = Unit.Meter;
                        // Set the source for the image file
                        acRasterDefNew.SourceFileName = strFileName;
                        // Load the image into memory
                        acRasterDefNew.Load();
                        //ed.WriteMessage("\nResMMPerPixel = " + acRasterDefNew.ResolutionMMPerPixel);
                        string x_y = dicImageInsertDetails["resmmperpixel_x_y"];
                        string[] xy = x_y.Split(',');
                        double x, y;
                        bool b = double.TryParse(xy[0], out x);
                        b = double.TryParse(xy[1], out y);
                        acRasterDefNew.ResolutionMMPerPixel = new Vector2d(x, y);
                        // Add the image definition to the dictionary
                        acImgDict.UpgradeOpen();
                        acImgDefId = acImgDict.SetAt(strImgName, acRasterDefNew);
                        acTrans.AddNewlyCreatedDBObject(acRasterDefNew, true);
                        acRasterDef = acRasterDefNew;
                        bRasterDefCreated = true;
                    // Open the Block table for read
                    BlockTable acBlkTbl;
                    acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
                    // Open the Block table record Model space for write
                    BlockTableRecord acBlkTblRec;
                    acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                    // Create the new image and assign it the image definition
                    using (RasterImage acRaster = new RasterImage())
                        acRaster.ImageDefId = acImgDefId;
                        string layername = dicImageInsertDetails["layer"];
                        LayerTable lt = acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForRead) as LayerTable;
                        if (lt.Has(layername))
                            acRaster.Layer = dicImageInsertDetails["layer"];
                        else
                            //WriteMessage("\nlayer not found: "+layername);
                        // Use ImageWidth and ImageHeight to get the size of the image in pixels (1024 x 768).
                        // Use ResolutionMMPerPixel to determine the number of millimeters in a pixel so you
                        // can convert the size of the drawing into other units or millimeters based on the
                        // drawing units used in the current drawing.
                        // Define the position for the image
                        string x_y = dicImageInsertDetails["insertionpoint"];
                        double x, y;
                        Point3d insPt = new Point3d(x, y, 0.0);
                        string res = dicImageInsertDetails["resmperpixel_x"];
                        double re;
                        b = double.TryParse(res, out re);
                        Vector3d u = new Vector3d(acRaster.ImageWidth * re, 0, 0);
                        Vector3d v = new Vector3d(0, acRaster.ImageHeight * re, 0);
                        acRasterDef.ResolutionUnits = Unit.Meter;
                        acRaster.Orientation = new CoordinateSystem3d(insPt, u, v);
                        ed.WriteMessage("\nOrientation = " + acRaster.Orientation.ToString());
                        ed.WriteMessage("\nu /v vector = " + u.ToString() + " - " + v.ToString());
                        ed.WriteMessage("\nResMMPerPixel = " + acRasterDef.ResolutionMMPerPixel);
                        ed.WriteMessage("\nRasterDefSize = " + acRasterDef.Size);
                        ed.WriteMessage("\nResolutionUnits = " + acRasterDef.ResolutionUnits);
                        // Set the rotation angle for the image
                        acRaster.Rotation = 0;
                        if(backgroundTransparent)
                            acRaster.DisplayOptions = ImageDisplayOptions.Transparent;
                        // Add the new object to the block table record and the transaction
                        acBlkTblRec.AppendEntity(acRaster);
                        acTrans.AddNewlyCreatedDBObject(acRaster, true);
                        // Connect the raster definition and image together so the definition
                        // does not appear as "unreferenced" in the External References palette.
                        RasterImage.EnableReactors(true);
                        acRaster.AssociateRasterDef(acRasterDef);
                        //Draw order - to bottom
                        //Entity ent = acTrans.GetObject(acRaster.ObjectId, OpenMode.ForRead) as Entity;
                        //BlockTableRecord block = acTrans.GetObject(acRaster.ObjectId, OpenMode.ForRead) as BlockTableRecord;
                        //dRAWoRDER
                        DrawOrderTable dot = acTrans.GetObject(acBlkTblRec.DrawOrderTableId, OpenMode.ForWrite) as DrawOrderTable;
                        ObjectIdCollection objToMove = new ObjectIdCollection();
                        objToMove.Add(acRaster.ObjectId);
                        //objToMove.Add(acRasterDef.ObjectId);
                        dot.MoveToBottom(objToMove);
                        acRaster.ColorIndex = 256;
                        if (bRasterDefCreated)
                            acRasterDef.Dispose();
                    // Save the new object to the database
                    acTrans.Commit();
                    // Dispose of the transaction
with a script this is fairly easy to do.
First you´ll need to establish FILEDIA = 0, in order to avoid dialogue windows.
The script is a simple textfile with extension *.scr and contains the following lines:
MAPIINSERT
D:\Image.ecw
N
Just execute the command MAPIINSERT once manually and you´ll understand the lines of the script.
It should be possible to call the same command from C#, although I haven´t tried it yet.
Best regards, Jack.
https://geomarker.wordpress.com/
Just to let you know, you can use "sendstringtoexecute" command and work on that, it is like typing the command line.
t_jevdjic
Could I insert multiple images (with tfw file) this way without dialog box?
It asks to check checkedlistbox.
I do not know how to make reversible process, when I have tfw and tif, because as I understood there should be some calculation about projection of the image. So I concluded that easiest way in my case, is to use mapiinsert. I have to choose amongst 1000 tif files particular files, and when I found these,  I do not know how to do the opposite math.. I'm not geodetic specialist, but I suppose that it could be done with some math.
I would appreciate some help regarding this issue...
best,
t_jevdjic
Hi all,
I solved this issue in C# using this tutorial and mapiinsert command.
No need for scr file..
It worked for me.
Besides that I appreciated Gile's posts, so it helped me to solve this issue.
Now,
I would like to do that via fdo.
It requires some learning about that.
here is try part from my button on click:
try
await docManager.ExecuteInCommandContextAsync(
async (obj) =>
await ed.CommandAsync( "FILEDIA", "0" );
await ed.CommandAsync( "CMDECHO", "0" );
foreach (var raster in rasters){
// MessageBox.Show(raster);
await ed.CommandAsync( "mapiinsert", raster, "N" );
await ed.CommandAsync( "FILEDIA", "1" );
await ed.CommandAsync( "CMDECHO", "1" );
await ed.CommandAsync( "ZOOM", "E" );
null
this.UncheckAllItems();
