Map Image insert & VBA Object Model....
Hello all.
I want to create a function to insert and image using the Map Insert Image
command.
After searching, I don't believe this is part of the Object Model...
I do however have a 'CAD Overlay' reference installed on this machine...
I don't think CAD Overlay has ever been installed on this machine, so I'm
wondering if this reference has been istalled by Map, and this is way to
tackle this?
I can call the command via 'Sendcommand' to accomplish this, but was hoping
I could avoid that?
Ideas?
Warren M
Warren,
I also have the CO 2002 libray on my machine - Map 2002 must install it
since it is using the CO engine for rasters.
Take a look at the aecImageInsert Class.
For reference, look at ActiveX.hlp in the Cad Overlay\help folder.
Hope This helps,
Scott
"Warren Medernach" wrote in message
news:5E33D29107BC6FA9FD94DF200F809E8A@in.WebX.maYIadrTaRb...
> Hello all.
> command.
> tackle this?
hoping
> I could avoid that?
> Ideas?
> Warren M
Hey Scott.
That's kind of the problem...
There is no CO directory on a Map install... at least not on mine?
I checked out a machine that does have CO installed and found the
ActiveX.hlp file with all of the examples, You'll see the examples are
calling an ARX to see if CO is loaded, AeciUi20.arx, but this ARX is not on
a machine that only has Map?
So I'm starting to wonder if this is possible from the Map api?
Warren
"Scott Friedrich" wrote in message
news:5FDDE974B82706D593F0EEF3310EDC23@in.WebX.maYIadrTaRb...
> Warren,
> Hope This helps,
> Scott
> > Hello all.
> > command.
I'm
> > tackle this?
> hoping
> > I could avoid that?
> > Ideas?
> > Warren M
Sorry about that - I was at a machine with CO Installed. I do have a WS
with only Map 2002 and I am able to ref CO. The arx is in the 'Program
Files\Common Files\Autodesk Shared' folder.
news:3F390664510D0FF4914240E3869683D6@in.WebX.maYIadrTaRb...
> Hey Scott.
on
> Warren
> > Warren,
> > Hope This helps,
> > Scott
> > > Hello all.
> Image
> > > command.
machine...
> I'm
to
> > > tackle this?
> > hoping
> > > I could avoid that?
> > > Ideas?
> > > Warren M
I can't see the AeciUi20.arx file anywhere, even on the machine with CO
installed?
From what I can see, the arx's that Map loads when the Image command is
executed are:
AeciIb22.arx
AeciIbApi22.arx
AeciUiBase22.arx
And the 'Autodesk CAD Overlay 2.2 Object Library' reference in VBA points to
'AeciIbCom22.dll'?
Scott, do you have any of this working in Map, ie attaching images via VBA?
Warren M
news:9AFBB6E1B83E9F83A1B152729DB9A657@in.WebX.maYIadrTaRb...
> > Hey Scott.
> on
> > Warren
> > > Warren,
it
> > > Hope This helps,
> > > Scott
> > > > Hello all.
> > Image
> > > > command.
> machine...
so
> > I'm
way
> to
> > > > tackle this?
> > > hoping
> > > > I could avoid that?
> > > > Ideas?
> > > > Warren M
Warren,
Apparently we are not able to use the CO api with vanilla Map - I can not
find AeciUi20.arx
on the machines that do not have CO installed either. All of my testing
has been with CO installed with Map or LDT. One workaround is to use the
acadRasterImage in vanilla AutoCAD - this will not read the resource file
but you could do that programmatically - or use the sendcommand.
news:E3B642F74F1CF8F0AD18771060D3B8FF@in.WebX.maYIadrTaRb...
> installed?
> executed are:
> AeciIb22.arx
> AeciIbApi22.arx
> AeciUiBase22.arx
to
> 'AeciIbCom22.dll'?
VBA?
> Warren M
> > > Hey Scott.
not
> > on
> > > Warren
> > > > Warren,
> it
> > > > Hope This helps,
> > > > Scott
> > > > > Hello all.
Insert
> > > Image
> > > > > command.
Model...
> > machine...
> so
> > > I'm
> way
> > to
> > > > > tackle this?
was
> > > > hoping
> > > > > I could avoid that?
> > > > > Ideas?
> > > > > Warren M
