Attach a data source programmatically
Hi
How can I programmatically attach a data source to the project workspace using Object ARX?
if you are using Autodesk Map 3D 2005, you can use the new API AcMapDataSources. There is an example in the Map samples section of the object arx
hope that helps
Jim Bower
