Map 3D 2005-Error loading arx
I get this message on the command line at startup
C:\Program Files\Autodesk Map 3D 2005\civil\AeccUiLand15.arx cannot find a dll
or other file that it needs.
C:\Program Files\Common Files\Autodesk Shared\GIS\FDO\SysAdmin.arx cannot find
a dll or other file that it needs.
I can load them with appload and they work. But they won't start during startup?
Make sure search path (Options->Files->Support File Search Path) contains these two directories. C:\Program Files\Autodesk Map 3D 2005\civil C:\Program Files\Common Files\Autodesk Shared\GIS\FDO -PG. "eo1bart" wrote in message news:9459421.1083891190506.JavaMail.jive@jiveforum1.autodesk.com... > I get this message on the command line at startup > > C:\Program Files\Autodesk Map 3D 2005\civil\AeccUiLand15.arx cannot find a dll > or other file that it needs. > C:\Program Files\Common Files\Autodesk Shared\GIS\FDO\SysAdmin.arx cannot find > a dll or other file that it needs. > > I can load them with appload and they work. But they won't start during startup?
Thanks, that did the trick
You are welcome. "eo1bart" wrote in message news:21847423.1083968453832.JavaMail.jive@jiveforum2.autodesk.com... > Thanks, that did the trick
