HOW TO INSERT A SID IMAGE
dancalgary
dancalgary
I have the following command:
it is failing at the line importer.Init("SID", "C:\\Users\\xxx\\Documents\\Work Files\\_tst\\RIDG-A-1003.sid");
can you please help me?
[CommandMethod("InsertSIDImage")]
public void InsertSIDImage()
// Get the active document and database
Document ThisDrawing = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database Database1 = ThisDrawing.Database;
using (DocumentLock lock1 = ThisDrawing.LockDocument())
// Start a transaction
using (Transaction Trans1 = Database1.TransactionManager.StartTransaction())
BlockTableRecord BTrecord = Trans1.GetObject(ThisDrawing.Database.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
try
MapApplication Acmap = HostMapApplicationServices.Application;
Importer importer = Acmap.Importer;
ImportResults results;
results = importer.Import(true);
catch (Autodesk.Gis.Map.MapImportExportException ex)
// Check if ex has more specific properties related to the error
MessageBox.Show(ex.Message);
if (ex.InnerException != null)
MessageBox.Show("Inner Exception: " + ex.InnerException.Message);
MessageBox.Show("Stack Trace: " + ex.StackTrace);
catch (System.Exception ex)
Trans1.Commit();
norman.yuan
Are you sure Map 3D can import *.sid file?
Norman Yuan
Drive CAD With Code
norman.yuan
*.sid file is kind of image file, not data file (the data as geometries), thus, you do not use Map's ImportExport API to import it, you insert the image into map drawing. This discussion in the C3D forum would be of help:
https://forums.autodesk.com/t5/civil-3d-forum/importing-sid-from-gis-to-autocad/td-p/7638421
Norman Yuan
Drive CAD With Code
