How to CreateLink with CAO in VC++ in Autodesk Map 5?
Message 1 of 1
Hello. I have the code as follows:
(*pAcadApp)->GetInterfaceObject(_bstr_t("CAO.KeyValues"),&pDisp);
pDisp->QueryInterface(&pKeyValues);
pDisp->Release();
//set the value
if (S_OK != pKeyValues->Add(_bstr_t(linkname), _variant_t(_bstr_t(LPCTSTR(strLink))), &pKeyValue))
acutPrintf("\nError: Can't add a value from KeyValues.");
return Acad::eInvalidInput;
//create a new link
if (S_OK != pLT->CreateLink (idEnt.asOldId(), pKeyValues, &pLink)) // HERE IS THE PROBLEM !!
acutPrintf("\nError: Unable to create the link from the LinkTemplate.");
I can't create a link to an entity because CreateLink instruction does not work correctly, it returns NULL the pointer to the link (pLink), and does not create the link.
Anybody kwnows why it fails?
Is correct the call to the KeyValues->Add function? Perhaps the second parameter (VARIANT Value) must to be different VARIANT type? I have proved all VARIANT types to the value, but nothing seems to be correct.
Replies (0)
