Editor.command
Editor.command
giskumar
Editor.command
giskumar
Hi All,
Below code is working fine for me
[CommandMethod("T")]
        public void T()
            Autodesk.AutoCAD.ApplicationServices.Document doc =
                   Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            List<ObjectId> oidlist = GlobalFunction.SS.ClsSelection.GetEntsOnScreen("*", "*");
            PromptPointResult ppr = ed.GetPoint("");
            Point3d pt1 = ppr.Value;
            Point3d pt2 = ppr.Value;
            Point3d pt3 = ppr.Value;
            Point3d pt4 = ppr.Value;
            try
                ed.Command("_.ALIGN", oidlist[0], "", pt1, pt2, pt3, pt4, "", "Y");
            catch (System.Exception ex)
                MessageBox.Show(ex.Message);
            MessageBox.Show("Hi");
            ed.Command("_.Circle", new Point3d(), 1.0);
But when i call below line from form button click, it is throwing error invalid input.
Any one plese help me where i am doing mistake.
Kumar.
just Google it - you will find plenty of examples such as
http://stackoverflow.com/questions/29371567/calling-autocad-commands-from-c-net
norman.yuan
What kind of form? modeless form/PaletteSet, which is usually shown from a session command? Or modal form?
Keep in mind, Editor.Command() only works in document context, not in application context.
Norman Yuan
Drive CAD With Code
giskumar
Thanks for the reply.
It's a pallet set shown from a session command.
Thanks & Regards,
Kumar.
norman.yuan
Therefore, you cannot use Editor.Command().
However, you can use Document.SendStringToExecute(....), where the Document is Application.DocumentManager.MdiActiveDocument.
Norman Yuan
Drive CAD With Code
