Cannot Attach and Edit Object Data from C# Winform
Dear Better Experienced Collegues,
I am having a serious issue attaching object data to an object. I am providing the tableName from another part of the program as a string, the name of the field which is being converted from a hashtable into the position of the field in the record [will change this later], and the value is coming from a combo box in a winform. Please note that I have locked the drawing early in this procedure, based on the information in a post I felt may have been related. I am not handling the exception as I am stepping through the code with VS2010 Expression for C#, but will handle any exceptions later. Just to be clear, I am using Autodesk Map 2011. Here is my c# (c sharp) code:
public static bool CommandAddData(string tableName, string updateField, string cmbValue)
            Document dwg = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            using (DocumentLock lk = dwg.LockDocument())
                Tables tables = HostMapApplicationServices.Application.ActiveProject.ODTables;
                ObjectId[] selObjs = SLiiCGIS.GISFunctions.SelectionFunc.selectedObjects.Value.GetObjectIds();
                // Get Application Level Table Definition for object data
                Hashtable masterTableDef = SLiiCGIS.ApplicationVariables.tableDefinition;
                if (selObjs.Length > 0)
                    foreach (ObjectId sel in selObjs)
                        Autodesk.Gis.Map.ObjectData.Table table = tables[tableName];
                        using (Records rcds = tables.GetObjectRecords(0, sel, Autodesk.Gis.Map.Constants.OpenMode.OpenForWrite, false))
                            if (rcds.Count == 0)
                                try
                                    // Create and initialize an record
                                    Autodesk.Gis.Map.ObjectData.Record tblRcd = Autodesk.Gis.Map.ObjectData.Record.Create();
                                    table.InitRecord(tblRcd);
                                    int tblPos = Convert.ToInt32(masterTableDef[updateField]);
                                    MapValue val = tblRcd[tblPos]; // String type
                                    val.Assign(cmbValue);
                                    table.AddRecord(tblRcd, sel);
                                    return true;
                                catch (MapException)
                                    return false;
                            else
                                try
                                    foreach (Autodesk.Gis.Map.ObjectData.Record tblRcd in rcds)
                                        int tblPos = (int)masterTableDef[updateField];
                                        return true;
                                    return false;
                    return true;
                else
                    return false;
Almost directly out of the book (AutoCAD Map 3D SDK | ObjectARX .NET Developer's Guide | Object Data | Attaching Object Data). Any assistance would be greatly appreciated.
Please try this code...
        #region Add Or Update Object Data Record
        public static bool AddOrUpdOD(string TableName, ObjectId objectID, string columnName, string value)
			Autodesk.Gis.Map.ObjectData.Tables tables = Autodesk.Gis.Map.HostMapApplicationServices.Application.ActiveProject.ODTables;
			Autodesk.Gis.Map.ObjectData.Table table = tables[TableName];
			Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
			int recCount = 0;
			try
				using(DocumentLock lk = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument())
					using(Records rcs = table.GetObjectTableRecords(0, objectID, Autodesk.Gis.Map.Constants.OpenMode.OpenForWrite, false))
						recCount = rcs.Count;
					if(recCount == 0)
						Record Rec = Record.Create();
						table.InitRecord(Rec);
						table.AddRecord(Rec,objectID);
					using(Records records = table.GetObjectTableRecords(0, objectID, Autodesk.Gis.Map.Constants.OpenMode.OpenForWrite, false))
						if(records.Count == 0)
							ed.WriteMessage("\nObject Data attachment failed.");
							records.Dispose();
							return false;
						foreach(Record Recd in records)
							for(int i = 0; i < Recd.Count; i++)
								FieldDefinitions tblDefs = table.FieldDefinitions;
								FieldDefinition column = null;
								column = tblDefs[i];
								if(column.Name.CompareTo(columnName) == 0)
									Recd[i].Assign(value);
									records.UpdateRecord(Recd);
									break;
				return true;
			catch(Autodesk.Gis.Map.MapException Exp)
				System.Windows.Forms.MessageBox.Show("ERROR:" + Environment.NewLine + Exp.Message + Environment.NewLine + Exp.StackTrace);
				return false;
    	#endregion
this code works perfectly for me....
Thanks...
Chandan.
Hello Chandan,
Thank you very much, for saving my life. I will be analyzing the superiority of your code for at least 30 minutes 🙂
Could you please tell me how you are assigning the value to the ObjecID
I am trying to attach a record to the Acadline using
odTable.AddRecord(oRecord, OBjID)
Daniel.Du
You may want to select the entity and get the object id using following code snippet:
    Editor AcadEditor = Application.DocumentManager.MdiActiveDocument.Editor;
    PromptSelectionOptions options = new PromptSelectionOptions();
     // Single select mode
    options.SingleOnly = true;
    options.SinglePickInSpace = true;
    options.MessageForAdding = "Select an entity:";
    AcadEditor.WriteMessage("\n Please select an entity to add a record: ");
    PromptSelectionResult result = AcadEditor.GetSelection(options);
    if (result.Status != PromptStatus.OK)
        AcadEditor.WriteMessage("\n User cancelled! ");
        return;
    ObjectId[] ids = result.Value.GetObjectIds();
    if (ids.Length != 1)
        AcadEditor.WriteMessage("\n Invalid selection! ");
        return;
    //you code goes below...
    OBjID = ids[0];
Daniel Du
Developer Technical Services
Autodesk Developer Network
