Attaching object data within LISP
I am writing a lisp routine that will attach data associated to a polygon to a point that I create. Unfortunately, AutoCAD will not allow me to use the "_ADEATTACHDATA" command within LISP. Is there an equivalent within LISP that anyone knows about? I have tried searching on the net, but i can only come up with a command to add a record to an existing table.
Phil
Try 'ade_odaddrecord'. To get a description, from the AutoCAD Map Help menu,
choose Programming Interfaces, Visual lisp..., Interface Functions, Data
Extension Functions, then Object Data Functions.
as an example:
(setq atb_nm (ssname atb_ss 0); entity name
(setq atb_get (entget atb_nm)); get entity data
(setq atb_lyr (cdr (assoc 8 atb_get))); layer name
(if (= (ade_odgettables atb_nm) nil); if there is no table
(ade_odaddrecord atb_nm "NewTable")); attach table
(ade_odsetfield atb_nm "NewTable" "Layer" 0 atb_lyr); populate record
Eric Smallwood
"pj3768" wrote in message
news:f0a0285.-1@WebX.maYIadrTaRb...
> Phil
Thanks! I actually found the answer myself after about 2 hours of searching. I came back to post my findings, but you had already answered it. Thanks again.
Phil
Hi Phil,
Do you have an example code of how you are using it?  I'd like to grab all objects on a given layer and add a specific od table to it and even fill out some of the fields if possible.  I'm a newb at lisp so any help is appreciated.
Scott
