Align queried object data text to objects, Why did you nuke me?
Message 1 of 9
Its a legitimate question!
I have a network of roads and I want to align the names to the roads. The
only tools I see let me set the angle, justification, and label point (not
even offset). I have 1000s of streets and I'm looking for a way to
automatically align the queried data (names) to the line objects. Somebody
might clue me in. At least let it up for a couple of weeks and then delete
it. You only let it show for 2 or 3 days. Give me a break!
JK
Replies (8)
Message 2 of 9
JK, If you are refering to your post on Dec 4 it is still here, at least on my reader. To answer you question No there is no easy way to do it automatic. when you set the text ange in the query all the text gets set at that angle. You can use text justifaction to offset it from the road. .
Murph
Message 3 of 9
JK -
Your post is still here. Reset your discussion news reader to see
ALL posts. The default on MS Outlook Express 5.5 is 5 days.
Subject:
Can I align object data text to objects
Date:
Tue, 4 Dec 2001 07:35:19 -0800
"JK"
Newsgroups:
autodesk.map.developer
Anne Brown
Manager, Moderator
Autodesk Product Support Discussion Groups
Discussion Q&A: http://www.autodesk.com/discussion
JK wrote:
(snip) At least let it up for a couple of weeks and then delete
> JK
Message 4 of 9
JK,
We are currently adding such a functionality to our GeoTools program. It is
called 'QueryProc' - Query Processor, an extended functionality for 'Alter
Properties' queries. This program will allow the queried text labels to be
handled in much more innovative and imaginative ways than is possible with
just plain AutoCAD Map Query Properties.
I am afraid I cannot post the whole code here but this is not too diffcult for
a developer to figure out - Collect the queried objects section set and the
query created text labels selection set. These will have the same number of
objects and the corresponding index in each selection set are the object and
label link. Once you know this association, it is upto you to do what you
want.
Hope this helps. Do feel free to ask.
Regards
Rakesh Rao
> JK
AutoCAD customization for Engineering/Mapping/GIS
Get GeoTools @ http://www.4d-technologies.com/geotools
Build MyGeoTools @ http://www.4d-technologies.com/geotools/my_geotools.htm
FREE downloads : http://www.4d-technologies.com/techcenter
Message 5 of 9
Oops.
I apologize Anne.
"Anne Brown" wrote in message
news:3C16A4EA.A15BE405@autodesk.com...
> JK -
> Subject:
> Date:
> From:
> "JK"
> Newsgroups:
> Anne Brown
> Manager, Moderator
> > JK
Message 6 of 9
"J.Murphy" wrote in message
news:f0a06d6.0@WebX.maYIadrTaRb...
my reader.
Sorry. My fault. Call me CADD monkey, I've earned it.
I was deleted before for irrelevant (fairly) that's why I thought I got
nuked.
> To answer you question No there is no easy way to >do it automatic.
You ain't kidding. I've been trying for days to write a VBA macro that would
look at every line's x1,x2,y1,y2 make degrees out of the slope value but I
just have no experience programmming. I couldn't figure out how to feed it
to the rotation setting for each individual line. I have to get better at
this. Did you see Richard's lisp expression?! I have to learn some lisp.
> when you set the text ange in the query all the >text gets set at that
angle. You can use text >justifaction to offset it from the road. .
Justification still leaves the text touching the road (I have a centerline
network) but it doesn't matter because I still got to go around erasing the
text I don't want and making it look pretty, I'll grip-offset them then.
Some of the text comes up upside down but thats OK I'll just 180it.
Murph
Message 7 of 9
Thanks for the information Mr. Rao, I will look at your products.
"Rakesh Rao" wrote in message
news:3C16D4F6.97AB12DF@vsnl.net...
> JK,
is
for
the
of
and
> want.
> Regards
> Rakesh Rao
The
(not
Somebody
delete
> > JK
Message 8 of 9
Here is a lisp routine I found somewhere that helped me out.
(angtos (- (/ pi 2) (atan (/ (/ (if (> .y1 .y2) (- .x1 .x2) (- .x2 .x1)) .length) (sqrt (- 1 (expt (/ (- .x1 .x2) .length) 2)))))))
Use for the insertion point in the alter properties
Message 9 of 9
Correction...
I believe that line of lsp code should be used for the ROTATION... not the insertion point....
Warren M
