Add features to Map
Add features to Map
Add features to Map
Hello again,
I have another problem with my DLL for AutoCad.
In my previous post (here) I wanted to connect to a FDO source.
Now I have connected and queried the FDO and got a response in form of a FeatureReader.
but how can I add the features in the reader to the map?
My Code is as follows:
Dim document As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim database As Database = document.Database
Dim TM As Autodesk.AutoCAD.DatabaseServices.TransactionManager = document.Database.TransactionManager
Dim connManager As OSGeo.FDO.IConnectionManager = OSGeo.FDO.ClientServices.FeatureAccessManager.GetConnectionManager()
Dim conn As OSGeo.FDO.Connections.IConnection = connManager.CreateConnection("Autodesk.Oracle.3.9")
conn.ConnectionString = "Service=SRID;Username=USERNAME;Password=PASSWORD;Datastore=SCHEMA"
conn.Open()
Dim Transaction Autodesk.AutoCAD.DatabaseServices.Transaction = TM.StartTransaction
Dim LayerTable As Autodesk.AutoCAD.DatabaseServices.LayerTable = CType(TM.GetObject(database.LayerTableId, OpenMode.ForRead, True, True), LayerTable)
Dim btr As BlockTableRecord = Transaction.GetObject(database.CurrentSpaceId, OpenMode.ForWrite)
Dim selCmd As OSGeo.FDO.Commands.Feature.ISelect = conn.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Select)
selCmd.FeatureClassName = New OSGeo.FDO.Expression.Identifier("VIEWNAME")
Dim ftrRdr As OSGeo.FDO.Commands.Feature.IFeatureReader = selCmd.Execute()
While ftrRdr.ReadNext()
       Dim geometryBytes As Byte() = ftrRdr.GetGeometry("SHAPE")
       Dim geometryFactory As New OSGeo.FDO.Geometry.FgfGeometryFactory()
       Dim geometry As OSGeo.FDO.Geometry.IGeometry = geometryFactory.CreateGeometryFromFgf(geometryBytes)
'What to do here? End While Transaction.Commit() conn.Close()
//Per
Hi Per,
Map SDK comes with lots of samples :
\Map ObjectARX SDK 2013\Map Samples\Platform
ADN has also published API introduction for Map - one example is here:
http://adndevblog.typepad.com/files/chapter-1.pdf
Rob
I realize now in hindsight that I wrote map when I should have written drawing.
Either way I found a way to add features from an FDO to a drawing.
Here is the code for inserting a linestring:
conn.Open()
       Dim linestring As OSGeo.FDO.Geometry.ILineString = CType(geometryFactory.CreateGeometryFromFgf(geometryBytes), OSGeo.FDO.Geometry.ILineString)
Dim PosCool As OSGeo.FDO.Geometry.DirectPositionCollection = linestring.Positions
Dim polyline As New Polyline()
For index As Integer = 0 To PosCool.Count - 1
Dim pos1 As OSGeo.FDO.Geometry.IDirectPosition = PosCool.Item(index)
polyline.AddVertexAt(index, New Point2d(pos1.X, pos1.Y), 0, 0, 0)
Next
Dim btr As BlockTableRecord = CType(Transaction.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
dim objectid as ObjectId= btr.AppendEntity(polyline)
Using document.LockDocument
Transaction.AddNewlyCreatedDBObject(polyline, True)
End Using End While Transaction.Commit() conn.Close()
 Hope it helps someone.
