Add FeatureReader to acSelection
Hi there,
I'm trying to add all fdo layer features to MgSelectionBase so I can turn on/off map layer features depending on the selection query.
here is what I have:
AcMapLayer maplayer = AcMapFeatureEntityService.GetLayer(objId); //objId is from prompt selection
MgFeatureQueryOptions queryOpts = new MgFeatureQueryOptions();
queryOpts.SetFilter("PRIMARYINDEX > 0"); //select everything on the layer
MgResourceIdentifier fsId = new MgResourceIdentifier(maplayer.GetFeatureSourceId());
MgFeatureService fs = AcMapServiceFactory.GetService(MgServiceType.FeatureService) as MgFeatureService;
MgFeatureReader featureReader = fs.SelectFeatures(fsId, maplayer.FeatureClassName, queryOpts);
AcMapSelection selBaseAll = new AcMapSelection(AcMapMap.GetCurrentMap());
//populate selection with all features
selBaseAll.AddFeatures(maplayer, featureReader, 0);
//hide all features
maplayer.SetFeatureVisibility(selBaseAll, false);
//turn on features that is passed as parameter to fn.
This works if the layer source is SDF file, but if the layer source is sql spatial, i get an error "An exceotion occured in FDO component. Property "GwsId" not defined for class "Classname"".  this is on line: selBase.AddFeatures(..);
That field "GwsId" doesn't exists in database, if you open it in sql studio.. what am I doing wrong?
Thank you,
-dm
Daniel.Du
When Map 3D connects to FDO data stores like Oracle/Sql Server and add layers to map, it will cache the data and use "GwsId" as identity key. Following code snippet works fine for Sql Server Spatial data store :
        [CommandMethod("SetVisible")]
        public void SetVisible()
            SetFeatureVisibility(true);
        [CommandMethod("setInvisible")]
        public void SetInvisible()
            SetFeatureVisibility(false);
        public void SetFeatureVisibility( bool visible )
            AcMapMap map = AcMapMap.GetCurrentMap();
            MgLayerCollection layers = map.GetLayers();
            MgLayerBase layer = layers.GetItem("FeatureClass1");
            AcMapLayer mapLayer = layer as AcMapLayer;
            MgFeatureQueryOptions opts = new MgFeatureQueryOptions();
            opts.SetFilter("ID > 0");
            MgResourceIdentifier featureId = new MgResourceIdentifier(mapLayer.GetFeatureSourceId());
            MgFeatureReader reader = mapLayer.SelectFeatures(opts);
            AcMapSelection selection = new AcMapSelection(map);
            selection.AddFeatures(mapLayer, reader, 0);
            reader.Close();
            mapLayer.SetFeatureVisibility(selection, visible);
Daniel Du
Developer Technical Services
Autodesk Developer Network
Hi
I have a question.
i would like to turn OFF/ON some set of FDO layers(Enterprises(Topobase Layers)).
The code is not working for me. Please help me
AcMapMap acMap = AcMapMap.GetCurrentMap();
MgLayerCollectionlayers = acMap.GetLayers();
if (layers != null&& layers.Count > 0)
foreach (MgLayerBase layer inlayers)
if(layer.GetVisible())
layer.SetVisible(
false);
//layer.Visible = false;//layer.ForceRefresh();
//if (layer.GetDisplayInLegend())//{// layer.DisplayInLegend = false;// layer.SetDisplayInLegend(false);// layer.ForceRefresh();//}
//AcMapMap.ForceScreenRefresh();
