AcMapMap problem in Civil3d 2011
I have simple program that look like this
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.Gis.Map.Platform.Interop;
using Autodesk.Gis.Map.Platform;
using Autodesk.AutoCAD.Runtime;
using OSGeo.MapGuide;
namespace probaAcMapMap
    public class Class1
        [CommandMethod("nesto")]
        public void nesto()
            AcMapMap map = AcMapMap.GetCurrentMap();
and I'm getting this exception "Failed to retrieve message for "MgInvalidArgumentException"."
This code is working just fine in 2010 and VS2008.
This code is builded with VS2010
Am I missing some reference or what?
norman.yuan
I tried your code with my AcadMap2011 and VS2010 (the project is set to target .NET4.0). It compiles OK and runs OK (this is the sigle line of code "AcMapAmp map=....' does not cause exception).
I believe civil3d 2011 has all AcadMap2011 functionalities plus more.
Well, to allow AcadMap2011 work with .NET 4.0, I have this in acad.exe.config:
<configuration>
 <startup useLegacyV2RuntimeActivationPolicy="true">
  <supportedRuntime version="v4.0"/>
 </startup>
</configuration>
Norman Yuan
Drive CAD With Code
I kindly figured out the problem. When I compile the program and start it, he throw an error. If I do that again (fresh start) except I call mapwspace command and than call my program, its ok.
I think it is because the map it is not initialized or something. If I look in my text window with F2 I saw some command like this MAPDMDWGLOADED???
I figured out. Reinstall solved the problem 🙂
