2013 map get objectdata record and values from table by name or selection
jcoon
Message 1 of 8
jcoon
Hi All,
I'm looking for help getting the objectdata record values from a selected table. I'm able to loop thru the list of tables and also select a table to be current, however I can't seem to get the records to displayed display, it tried ex: get records, but that didn't work, not sure why.
any ideas where I'm going work. I'm ultimate goal would be to select an Ent object in the dwg and connect to it's table to display the properties fields and values attached so I can edit them much list a properties dialog box, end the end I'd like to query the values in the table to display a layer and style.
any help, links or material I can read would be wonderful.
Thank you
John
                ex: get records
        odTable = acTableList.Item("obstacle")
                Dim odrecords As ObjectData.Records = odTable.GetObjectTableRecords(Convert.ToUInt32(0), id, Constants.OpenMode.OpenForWrite, True)
                Dim odRecord As ObjectData.Record = odrecords(0)
                MsgBox(odRecord.Count())
                MsgBox(odRecord.Item(0).StrValue)
<CommandMethod("readodatatables")> _
PublicSub readodatatables()
Dim ed AsEditor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor()
Dim db AsDatabase = HostApplicationServices.WorkingDatabase
Dim civilDoc AsCivilDocument = CivilApplication.ActiveDocument
Dim acaddoc AsDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim mapApp AsMapApplication
mapApp = HostMapApplicationServices.Application
Dim activeProj As Project.ProjectModel
activeProj = mapApp.ActiveProject
Dim ODtablename AsString
Dim mytrans AsTransaction = db.TransactionManager.StartTransaction
Try
Dim acBlkTbl AsBlockTable
acBlkTbl = mytrans.GetObject(db.BlockTableId, OpenMode.ForRead)
Dim acBlkTblRec AsBlockTableRecord
acBlkTblRec = mytrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
Dim BTMSpace AsBlockTableRecord = acBlkTbl(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite)
Dim acMapApp AsMapApplication = HostMapApplicationServices.Application
Dim acActiveProject As Project.ProjectModel = acMapApp.ActiveProject
Dim acTableList AsTables = acActiveProject.ODTables
Dim odTable As Autodesk.Gis.Map.ObjectData.Table
ForEach ODTables In acTableList.GetTableNames()
acTableList.GetTableNames.ToString()
ODtablename = ODTables
MsgBox("Table Name = " & ODtablename)
Next
MsgBox("number of tables in table list = " + acTableList.TablesCount.ToString)
MsgBox("Selected table =" + odTable.Name)
Catch exc As Autodesk.Gis.Map.MapException
EndTry
mytrans.Commit()
mytrans.Dispose()
EndSub
Replies (7)
Message 2 of 8
norman.yuan
Assuming the code for get ODTable record code is to be somewhere inside the CommandMethod code shown below, there are 2 things I noticed:
1. After getting the Records by
You'd better first test if the Records.Count==0 or not, before you call:
unless you are absolutely should ALL entities in modelspace have ODTable record attached. Also, this line of code
would raise exception: Record.Count is a property, not a method, thus you do not follow it with "()".
2. In the CommandMethod, you used
Try
Catch
End Try
I am strongly against using empty Catch clause, which simply silently eats unexpected exception and trys continue the execution. If you tried the Record retrieving code inside that "Try...Catch End Try" block in your command method, with the possible error as I methioned above, your code just goes through and does not tell you anything wrong. Unless you absolutely know you can ingnore exception in "Try..." clause and not harm will be done to the execution, never use an empty "Catch..." clause.
Norman Yuan
Drive CAD With Code
Message 3 of 8
jcoon
Norman.juan,
Thanks for taking a look and also for the description of areas to look for while working on this sample. I'll see what I can do during lunch today.
again thank you
John
Message 4 of 8
jcoon
I tried adding this from the map pdf sample getting OD, when I paste the sample I had an error as id, which I assume if the objectID so I added id as objectid , that seemed to pass the error, however when I run this section it stops at  "Dim odrecords As ObjectData.Records = odTable.GetObjectTableRecords(Convert.ToUInt32(0), id, Constants.OpenMode.OpenForWrite, True)" and never makes ti to the test for object type data from the FieldDefinition. I'm geting the correct table from the list of table, next should be the records in that table and then the acture values for each field,  is that coorect?
'MsgBox("Selected table =" + odTable.Name)
            If (odRecord.Count() > 0) Then
                For Each rec As ObjectData.Record In odrecords
                    For i As Integer = 0 To rec.Count() - 1
                        Dim val As Autodesk.Gis.Map.Utilities.MapValue
                        val = rec(i)
                        Dim fieldDefs As ObjectData.FieldDefinitions = _
                          odTable.FieldDefinitions
                        Dim fieldDef As ObjectData.FieldDefinition
                        fieldDef = fieldDefs(i)
                        ed.WriteMessage(
                        vbNewLine + fieldDef.Name + ": ")
                        Select Case val.Type
                            Case Constants.DataType.Character
                                ed.WriteMessage(val.StrValue)
                            Case Constants.DataType.Integer
                                ed.WriteMessage(val.Int32Value.ToString)
                            Case Constants.DataType.Point
                                ed.WriteMessage("point")
                            Case Constants.DataType.Real
                                ed.WriteMessage(val.DoubleValue.ToString)
                            Case Else
                                ed.WriteMessage("undefined")
                        End Select
                    Next
                Next
            End If
            odrecords.Dispose()
Message 5 of 8
norman.yuan
ODTable.GetObjectDataTableRecords() returns Records (plural), its Count could be 0 (i.e. the eneity does not have any ODTable record attached to it).
As I pointed out in previous reply, see this line of code right after calling GetObjectTableRecords():
Dim odRecord As ObjectData.Record = odrecords(0) ''<--if odrecords.Count=0, this line of code will raise exception
Norman Yuan
Drive CAD With Code
Message 6 of 8
jcoon
I was finally able to connect to a named table and display the value for item (0) for table obstacle, I'd like to ask another question; I'm looking for links that show how I could read and then set the the number of fields (items) in a table so I can display that data in a datagridview so I can edit item values.
second, is it possible to window autocad items and return the tables that are present in the window that I could then select from or place in a tree or combobox
Thanks for all your help
John.
<CommandMethod("ObjectdataReadrecords2")> _
    Public Sub ObjectdataReadrecords2()
        Dim acaddoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor()
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim acMapApp As MapApplication = HostMapApplicationServices.Application
        Dim acTableList As Tables = acActiveProject.ODTables
        Dim findtable As String = "obstacle" 'table name
        Dim trans As Transaction = db.TransactionManager.StartTransaction()
        Try
        Dim returnval As Integer = 0
            Dim mapvalstr As String
            Dim mapvalodstr As String
        Dim tables As ObjectData.Tables = HostMapApplicationServices.Application.ActiveProject.ODTables
        Using doclock As DocumentLock = acaddoc.LockDocument
                Using mytrans As Transaction = db.TransactionManager.StartTransaction
                    'Open the Block table for read
                    Dim acBlkTbl As BlockTable
                    Dim acBlkTblRec As BlockTableRecord
                    '' Open Model space for write
                    Dim odrecords As ObjectData.Records = tables.GetObjectRecords(0, acBlkTblRec.ObjectId, Constants.OpenMode.OpenForRead, False)
                    If odrecords.Count > 0 Then
                        For Each odrec As ObjectData.Record In odrecords
                            If odrec.TableName.ToUpper = findtable.ToUpper Then
                                mapvalstr = odrec.ToString
                                returnval += 1
                                mapvalodstr = odrec.Item(0).StrValue
                                ed.WriteMessage(vbCrLf + vbLf & "Record from Item(0)" & mapvalodstr.ToString)
                            End If
                        Next
                    End If
                    mytrans.Abort()
                End Using 'transaction
        End Using 'document lock
        Catch ex As Exception
        End Try
    End Sub
Message 7 of 8
norman.yuan
If I understand you correcctly: you want to dispaly the OD data in a tabular format, such as in a gridview. So, the first thing you need to do is to define the gridview's column (fields of the ODTable), while before your code runs you may not know what fields an ODTable has.
You can get ODTable's fields (name, value type..) from ODTable.FieldDefinitions property. Once you know the ODTable's field names, value types, then you can dynamically added columns in GridView. Then you retrieve OD records into a IList collection and bind the collection to the GridView. It sounds quite simple, but the code might be quite long for doing thisSmiley Sad.
As for your second question, yes, instead of looping through all entities in modelspace, you first do a window selection, using one of the Editor.SelectXXXX() method to obtain a SelectionSet of entities. You can apply properly defined filter to narrow down the target entities being seleccted. Then you only loop through the smaller set of entities to retrieve ObjectData.
Norman Yuan
Drive CAD With Code
Message 8 of 8
jcoon
norman.yuan,
I was able collect the FieldDefinitions and then the ObjectData.FieldDefinition for the named table and the map record values. It's been very busy at work so I had to put this down for awhile, but with your help I was able to move it along a little more. I'll try to tackle the grid next.
thank you
john
