昨日のWINDOWS11の更新後、図面を開いて(保存して)閉じるとフリーズ
topdog21
topdog21
昨日のWINDOWS11の更新後、図面を開いて(保存)閉じると「ピロン」と警告音?がなり、完全フリーズしてしまいます。
タスクマネージャで停止しなければなりません。図面は保存されてるようですが、1図面毎、フリーズでは・・・
皆様はどうですか?
0 件のいいね
返信
637件の閲覧回数
15件の返信
返信 (15)
paullimapa
What AutocadLT version are you running?
Inside LT enter About command, do a screenshot and post that here.
Paul Li
IT Specialist
@The Office
0 件のいいね
topdog21
Thank you.
I will attach photos and videos.
Looking forward to hearing from you.
0 件のいいね
paullimapa
解決済み
Looks like you don't have the latest 2022LT updates installed:
AutoCAD LT 2022 Help | AutoCAD LT Updates | Autodesk
Paul Li
IT Specialist
@The Office
0 件のいいね
topdog21
Thank you.
However, I couldn't find the update page and was able to get it to work normally by going to "All apps" and then "Reset settings to default."
Thank you for your advice.
0 件のいいね
paullimapa
Good that the reset worked for you. But you should still download and install the latest updates by following these instructions
Paul Li
IT Specialist
@The Office
0 件のいいね
topdog21
Thank you.
However, even if I follow your advice, the updates for AUTOCAD LT 2022 are not displayed.
Could this be because AUTOCAD LT will end with 2022 in Japan?
0 件のいいね
topdog21
Thank you.
0 件のいいね
paullimapa
解決済み
Well, if you're on subscription, you should be able to download up to 3 versions back.
https://www.autodesk.com/support/download-install/individuals/configure/download-older-versions
Since we're only on 2025, that would mean 2024, 2023 & 2022.
Perhaps create a support ticket:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-find-whe....
Paul Li
IT Specialist
@The Office
0 件のいいね
topdog21
Thank you.
I was able to download AUTOCAD LT2025.
But I can't activate it.
0 件のいいね
paullimapa
I recommend you post this problem of not being able to activate your 2025LT here
Paul Li
IT Specialist
@The Office
0 件のいいね
paullimapa
解決済み
Compare your management account sign in with what’s shown on this thread to verify you actually have a subscription to AutoCAD LT
Paul Li
IT Specialist
@The Office
0 件のいいね
topdog21
Sorry.
I had a standalone license.
There were no subscription licenses for AUTOCAD LT in Japan.
Thank you.
0 件のいいね
mari.shimode
@topdog21 さん、こんにちは。
参考となる情報を得られたようで良かったです。
同じようにお困りの方が解決策をみつけやすいように、topdog21 さんのお礼の返信を解決策から外しました。
また、paullimapa さんのこちらの返信も参考になったようですので、追加の解決策として承認しました。
ご自分の返信を解決策として承認するのは、ご自身で方法や回答をみつけたときのみでお願いいたします。
Mari Shimode
0 件のいいね
Misean
こんにちは。
既に解決済みとされていますが、以下の現象と一致するようでしたので
参考になればと思い、投稿いたします。
■図面に対して保存、閉じる、または印刷の操作を実行しようとすると AutoCAD がクラッシュまたはフリーズする
https://www.autodesk.com/jp/support/technical/article/caas/sfdcarticles/sfdcarticles/JPN/AutoCAD-cra...
原因は「ファイル」「ハードウェア」「ネットワーク」
「ユーザープロファイル」「サードパティ」など、多岐に渡って考えられるようです。
ドライバを最新にする、設定を既定にリセットする、図面修復など、
解決策が多数紹介されていますので、
お手数かと思いますが、1つずつお試しになられてはいかがかと存じます。
参考になれば幸いです。
Misean (M.Kawasaki)
topdog21
ありがとうございます。
結局、AUTOCAD LT2022の設定を規定にリセットすると何事もなかったように動作しました。
複数台のPCでWINDOWS更新の24H2が実施されたPCのみで、この事象が発生しました。
それまでの23H2(だったかな?)までは何も問題ありませんでした。
再ユーザー設定が必要になりますが自分の場合は大したことがなかったので良かったです。
情報ありがとうございました。
