Your coordinate system library is not available
JesusSubires
JesusSubires
I have a drawing that I want to geolocalise.
The coordinates of the drawing are set in Geographical coordinates from Belgium (Belge72 i.e. EPSG 31370).
During the geolocalisation procedure (Insert/ SET LOCATION /FROM MAP), I get the message "Your coordinate system library is not available".
As a result the drawing and the map do not overlap properly.
Is there a way to get and install geographical coordinates library for Belgium?
Thanks.
Replies (9)
cadffm
also in a NEW acadisolt.dwt based DWG ?
What is your productversion? Command: ABOUT
Sebastian
JesusSubires
Indeed when creating a new drawing from acadltiso.dwt, the message does not appear.
Product Version: R.154.0.0 AutoCAD LT 2021.1.1.
cadffm
Ok, then please share this dwg (you can erase all normal cad objects and saveas Copy, if you like)
Sebastian
JesusSubires
Herewith a copy the drawing.
I have erased a large part of the original objects.
Thank you
cadffm
That's normal because you changed the units! (right?)
Your File is set up to use imperial units, but you changed to Meters and in this case (or for the opposite cases)
you get this message.
The question is: How clever is it to use meters in a imperial setting(DWG) ?
The main thing for MEASUREINIT is controling default hatchpattern- and linetyp-definition,
but also for initial aec- setups and more. It seems GEOLOCATION is one more command
what is looking for this setting.
Sebastian
JesusSubires
The drawing is not in Imperial Units.
Please see attachment.
I am not sure to follow you .
Yes I was requested to confirm Drawing Unit (i.e. meters) during "Geographic Location - Set Coordinate System' procedure.
cadffm
This a a nice dialog, but has nothing to do with it.
Read more about measurement  in your help[F1] or ask your mentor (if available)
Sebastian
JesusSubires
Noted.
But how to get the drawing properly set on the satelitte image?
Furhter to your previous memo, I have used MEASUREMENT instruction to turn the drawing back to metric (value <1>).
I have proceeded afterwards with SET LOCATION /FROM MAP.
But the drawing is still offset compared to the satellite image.
PS/ The drawing is effectively drawn in meters.
When I import it in a GIS, there it fits perfectly.
cadffm
Hey, we don't have your data, how should i see what's going wrong?
And for me: I am not an expert about geo-locations, but we have somebody in our community.
Upload your file an tell us where it should be (coordinates and it would be perfect if we would have a lake, house or something like this to "see" the issue.).
My only try: Are you sure it is just "moved" to the wrong location, but the size is correct?
Just a question.. because we can not check this without your cad data.
I am out, the topic-issue is solved! I think an expert will check your DWG
Sebastian
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
