Windows taskbar disappears
cvanriper
Message 1 of 11
cvanriper
I am using AutoCAD LT 2025 with Windows 10 on 2 displays. Sometimes, the taskbar on display 1 disappears, but remains on display 2. I use Autocad on display 1. When I close AutoCAD, it returns. Does anyone else have this problem and know of a remedy for this?
Replies (10)
Message 2 of 11
RSomppi
Your AutoCAD window might not be maximized even though it fills up the entire screen.
Soution: Maximize the window using the button at the top right corner.
Message 3 of 11
pendean
Community Legend
Community Legend
Is this a sudden new problem, or did you just add a second monitor for the first time?
Is this a laptop/external monitor setup? Of two monitors attached to a desktop?
Or are you using VPN to access your office computer from your home computer and this is your home-only problem?
If the tip above does not help, your Win10 issue may need other fixes
https://www.google.com/search?q=windows+10+taskbar+disappears+on+the+second+monitor
Message 4 of 11
cvanriper
I thought of that. It's maximized.
Message 5 of 11
cvanriper
I have been using dual monitors for at least 7 years (WFH), so this is not new, but the issue seems to have developed since I started using LT about a year ago. I am using a desktop computer, not a laptop, and I am connecting to an office server through a VPN. I will look at the link you sent. I have a feeling this is an issue with Windows and how it might be interacting with AutoCAD since it always comes back when I close it. I'll also update my drivers to see if that corrects the problem. Thx
Message 6 of 11
bszaboFD3FB
I have this same issue. Had it previously on a PC with Win10 and still have the issue on a new PC with Win11. No VPN.
Message 7 of 11
m_houstonYQESV
Community Visitor
Community Visitor
I have this same issue as well, with the taskbar disappearing on display 1 but stays on display 2. For me, the taskbar will come back if you hit the Windows key on your keyboard. I don't know how to stop the taskbar disappearing but that's what I've been doing in the meantime
Message 8 of 11
pendean
Community Legend
Community Legend
@m_houstonYQESV Since dual monitors has been the norm for many of us for quite some time now... do you have the Windows Taskbar set to autohide on your Windows defined #1 monitor? Sadly no one in our offices (in-office or remote) have your issue issue, and I am unsure how to trigger it here in my setup. We are all in Win10Pro-Win11Pro, all of us are "local admin" logins, a mix of laptops (docking stations) and desktops (dual port video cards), all with dual side-by-side monitors, Windows default settings #1 and #2 monitors in "extend these displays" setting, landscape mode.
Message 9 of 11
cvanriper
"do you have the Windows Taskbar set to autohide on your Windows defined #1 monitor?"
No
Oddly, since I've made this inquiry, I have not experienced the problem much
Message 10 of 11
pendean
Community Legend
Community Legend
@cvanriper wrote:
...Oddly, since I've made this inquiry, I have not experienced the problem much
Odd indeed.
Message 11 of 11
m_houstonYQESV
Community Visitor
Community Visitor
No, I do not have it set to autohide. When it "disappears" it will leave a white box where the taskbar should be but no widgets/icon/date etc. When I press the Windows key it brings up the Start menu and the taskbar goes back to normal. But the second monitor will still have everything as normal either way. I'm using Win11Pro. My display 1 is a laptop and display 2 is a separate PC monitor. Doesn't matter if I'm hooked up to my work monitor or my home monitor, it will always disappear off my laptop. It's not the end of the world, just a bit annoying.
