AutoCAD LT Forum
Welcome to Autodeskโ€™s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
While I set lockation of dim text (above, center) the text is getting smaller
5 REPLIES 5
404 Views, 5 Replies
I have polish version of AutoCad LT 2017. In my drawing I want to change location of dim text (above, center). When I set a option for example above dim line the text is smaller then before operation.
I don't know what is going on. I attach three printscreens. This is polish version so commands are in my native language.
Please help me ๐Ÿ™‚
5 REPLIES 5
pendean
What is the text height assigned to the DIMSTYLE being used: is it the larger or smaller size?
Is there an override in place for that dimstyle?
in reply to: pendean
I think the best way to help you answer for this problem will be sending my *dwg file.
I always save my drawings once a day. File version from 10th January 2017 I don't have problem as I wrote in previous posts.
pendean
Change the height of the text style TMP-pikietaz to zero, or something larger than 0.75 (this is the small size you get, the large size you want seems to be 1.0 I assume or something close to it), and your problems go away.
You can't go around changing text style heights without consequences.
Tags (1)
Thank you very much for help.
Now it is seems so easy... ๐Ÿ™‚
Technology Administrators
