AutoCAD LT Forum
What does the asterisk indicate at the drawing name?
12 REPLIES 12
Message 1 of 13
tor3B3UK
3680 Views, 12 Replies
Why is this asterisk in the name of the drawing? Please see below
Also, I try 'closing' out one of the drawings and I get an error message that says: "Command _CLOSE is not available under SDI mode."
SDI is set = 1... How am I supposed to negotiate between drawings?
12 REPLIES 12
Message 2 of 13
user181
in reply to: tor3B3UK
Hi @tor3B3UK,  the asterisk after the drawing name means changes have been made since it was last saved.  SDI = 1 turns on the single drawing interface. If you are opening multiple drawings you want SDI = 0
Message 3 of 13
tor3B3UK
in reply to: user181
... means changes have been made since it was last saved.
The asterisk appears when first opening up a drawing before any edits have been made.
Message 4 of 13
user181
Thats how it works. Once you save it will go away but all you have to do is pan or zoom and it will come back.
Message 5 of 13
tor3B3UK
Is there any point to this 'feature' except to stymie productivity?
Message 6 of 13
cadffm
Rofl. How can this stymie your productivity?
If it isn't a profit for you to see if a file state is saved or not, ok.
Or do you mean that pan or zoom etc. set your file state to non-saved?
Easy answer, the current view is part of your stored data in your file.
If you have change the view, you changed the content.
Sebastian
Message 7 of 13
tor3B3UK
in reply to: cadffm
The wasted time is in not being able to negotiate between two drawings (SDI = 1 not working) and having to 'fix' all the problems that keep coming up over and over again due to this finicky program that is extremely unstable. I have gotten *dozens* of FATAL ERRORS over the last week from things that are completely out of my control. AutoCAD is a time-sink and it makes me very frustrated that it is so prone to problems despite paying tens-of-thousands of dollars for it. the asterisk is a brand-new 'thing' that just showed up this morning that I had no idea what it meant. Now you say it really doesn't 'do' anything except remind you that the drawing isn't 'saved'. Is this a 'feature' that just started this morning?
Message 8 of 13
pendean
You seem to be talking about way more than a simply asterisk in a tab: it has been around for ever, did you just move to a new version from a very old version?
Do you need to follow trough with one of your other posts in this forum?
What is your AutoCAD/LT version?
What is your Windows version?
Message 9 of 13
tor3B3UK
in reply to: pendean
Okay, sorry. It appears CAD has changed quite a bit with this forced SDI=0 thing that's new for me since the 2018 version.  CAD is doing their customer base a great disservice by changing many core features without legacy options.
Message 10 of 13
cadffm
As it has been said, this change has arisen from necessity because there are problems that could not be solved.
I tried using SDI on Win8.1 and have no problems (only because of some User questions i tried that) Maybe there is still an update? I don't no.
I am glad that SDI still existed in 2000-2018 😉
With MDI in 2000(?) and removing the documentation of SDI few years ago, it was ever possible that Adesk removes this old feature in the future.
Sebastian
Message 11 of 13
pendean
See your other duplicate posts.
Message 12 of 13
tor3B3UK
The asterisk is a brand new 'feature' that didn't occur on any drawing I have ever worked on in AutoCAD which creped up at random about a week ago right after I asked about docking my command line when someone had me do something to my system that radically changed its appearance by messing with the CUI which is apparently an *irreversible* option.  This question is not related to any other question I've asked.
Message 13 of 13
pendean
See your other duplicate posts, all of these same questions have been answered over and over again.
Technology Administrators
