Want to edit a LISP file
franschor
franschor
Community Visitor
Community Visitor
I want to edit a LISP file but get no permission to save it.
See attached picture.
Thanks!
pendean
Community Legend
Community Legend
Is your Windows log-in quite restrictive from your IT folks? That seems to be what you are showing/describing. Only they can help you out.
Bigger question though: why do you think you need to/ want to edit that file? It's not meant to be used by us end users
cadffm
That's usual for system program path.
Save it at another place and use ctrl+x / ctrl+v
I would prefer a custom folder, not in this system path.
Except you want to set up this PC for other users, and all of them should use the same file.
Sebastian
cadffm
Good point Pendean,
@franschor
You shouldn't edit acadlt2025 and acadltdoc2025
Create your own with the name
acadlt for program start
or
acaddoclt for each document!
Sebastian
franschor
Community Visitor
Community Visitor
I’m an old fashion 12 AutoCAD user and use the keyboard more than the mouse
and built a lot of commands by myself.
pendean
Community Legend
Community Legend
Yeah, those old ways need to remain in history. We all used to do a lot back then that never were a good idea.
You want to create your own custom-to-you folders, add them to search to your AutoCAD search paths, keep your custom content away from program folders, then create your own ACADLT.LSP and ACADLTDOC.LSP files to do what you need to do
And don't forget to add those LISP folders of your to this section otherwise the program will block them from running
HTH
paullimapa
Your lisp file can also automatically be loaded on startup by including it in autocad appload startup suite
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-B38F610B-51FB-4938-BDEC-A0A737F5DB6C
Paul Li
IT Specialist
@The Office
