- Mute
- Permalink
- Report
I am having a problem with the Draw Order of Viewports in my paper space. I typically have several Viewports on a sheet and they frames are set to plot so I can segment the sheet. When I click on the layout tab, all of the Viewport frames have been brought above the other objects on the sheet (i.e. my company border) and it will plot this way. If I select the border, and use the "Bring to Front" Draworder command, the border will view and plot over the Viewport frames (as I want it to).
The problem is when I select another layout tab, and then switch back, it has reverted (both display and plot) to pull the viewport frames above all other objects.
This is pretty frustrating since this means I cannot batch plot or else I have viewport frames display issues.
