Hi all,
Kind of have a weird issue here. I opened a dwg earlier today in LT 2018 and the viewport had a viewcube in it. I use Autodesk Fusion all the time, and love the viewcube function. I didn't think AutoCAD LT supported viewcube, and after some extensive googling, I've found out that it doesn't. Since closing the file, I cant seem to get the cube back. Is this some sort of bug or is there a sneaky way to use the viewcube in LT? Unfortunately I cant attach the file because I don't have authorization. Also, I know of the VPOINT command, and its just not as easy to use for the quick rotations that I would like to be doing.
Any help would be much appreciated, thanks!
Solved by pendean. Go to Solution.
I don't have the full version of autocad anywhere. I have LT Installed on my PC. Ive been using LT on this PC for about 4 months now and I've opened this file on several occasions without this happening.
um i have done this severl times as well an its something to do with layout it only comes sometimes in layout idk why an no i dont have any other cad programs on my work computer.
