View Multiple Layouts
Message 1 of 20
In acadlt 2016, is there a way to view/edit multiple layout tabs at the same time, side by side?  My sheets are drawn all in paper space so I can not use viewports.
Replies (19)
Message 2 of 20
h_s_walker
Welcome to the Forums
No you can't edit multiple layouts at the same time.
What exactly are you trying to do? We may be able to suggest a workaround
Howard Walker
Left Handed and Proud
Message 3 of 20
I'm create electrical schematics.  My company uses paper space only.  I'm having to go back and forth between tabs to add my references.  Just looking for an easier way without going to ACADE.
Message 4 of 20
h_s_walker
Can you post a couple of screenshots to show us exactly what it is you're referencing.
Howard Walker
Message 5 of 20
Basically, I want to view a layout tab while editing another.  Just like having multiple viewports on a layout.
Message 6 of 20
pendean
Community Legend
Community Legend
Any reason your edits can't be done in modelspace?
Are these references just sheet "pointers', like find this detail on sheet 10 of this set type thing? If yes, SSM might be able to help automate the task (not what you want, but a different workflow altogether).
OR
Open multiple LT sessions, park each on separate monitors or side by side if you only have one monitor. Remember, only one session can be used for editing, so the other is for viewing only.
Or talk the boss into ACADE.
Message 7 of 20
Emmsleys
Hello @Anonymous,
Welcome to the Autodesk community!
What if you have two instances of AutoCAD running side by side?
Something similar to what is explained here: How to view drawings side-by-side in AutoCAD
Sarah Emmsley
Technical Support Specialist
Message 8 of 20
Emmsleys
Hello @Anonymous,
I'm following up on my previous post if you have any questions or found a workaround post back with any new updates
If you still need help or have questions I'll be more than happy to help.
Thanks.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Message 9 of 20
Thanks for the suggestions.
My preference would be to work in model space but that's not my company's "standard practice".  Even though I've shown multiple benefits of doing so.
I don't see how multiple instances will work being it's one drawing file.
Other ideas?
Message 10 of 20
h_s_walker
Have two instances of AutoCAD open. Have the same drawing open in both (one will be read only) then edit in the non read only drawing
Howard Walker
Message 11 of 20
Yes.  I understand how to use and the limitations of 2 instances.  Not really what I was looking for.
Sounds like this would be a good future enhancement.
Message 12 of 20
Emmsleys
@Anonymous,
I'd also recommend you leave that feedback here:
https://www.autodesk.com/company/contact-us/product-feedback
I can also make an internal comment on this as well and provide an update should something be released that falls in line with what you're looking for. Smiley Happy
Sarah Emmsley
Message 13 of 20
Emmsleys
@Anonymous
Let me know if you are unable to access that link or run into any issues with that site.
Sarah Emmsley
Message 14 of 20
Emmsleys
Thanks.
Sarah Emmsley
Message 15 of 20
scottFXCZ3
I'm following up on this post.  I also want to view two layout tabs side by side at the same time in ONE instance of an AutoCAD file.  This seems really simple and happens quite easily in Revit.  Why can I not figure out how to do this in AutoCAD?  Please advise.
Message 16 of 20
cadffm
You can do the same workaround with just one program instance.
Open the second file session(readonly) and place bothe side by side.
"Why can I not figure out how to do this in AutoCAD?  Please advise."
Read this thread and you see: There is no feature like that
"This seems really simple"
Yes, simple!
Programs with this feature: Click, done
Prgs where it is impossible: Click often you want, you can't reach this goal.
Sebastian
Message 17 of 20
scottFXCZ3
@cadffm, thanks for such a quick response!  I sincerely appreciate it!
OK.  just seems really obtuse to have to open a second read-only copy of the same file.  Seems like it would take more memory than just dragging a layout tab over onto the other screen as we do in Google Chrome, Revit, or many other software packages these days.
Yeah, but this thread is over 5 years old now, so I was hoping the good folks at Autodesk had "gotten with the program" and added this simple but extremely useful feature.
Yes, simple!
You lost me there.  I think you are just trying to say yep... it IS really simple, but you can't get there from here!  🤣
Message 18 of 20
cadffm
Right: Still, you can't do that in this program.
"OK.  just seems really obtuse to.."
Right,
but we (all Users like you) can just explain the program and sometimes we can offer workarounds.
Only the manufacturer of the software can change this.
Send feedback to Autodesk and cross fingers.
You are not the first and not the last who like to do it.
Sebastian
Message 19 of 20
RobDraw
Expecting one program to act like another is simple. Getting it to do so is an entirely different story, especially when they are completely different platforms. When asking how to do something, you can use another program as an example but to say it has to be simple because this or that program does it is expecting too much and does nothing to get you what you want.
Rob
Message 20 of 20
scottFXCZ3
Fair enough.
