Message 1 of 14
- Mute
- Permalink
- Report
For years I've been using Adobe's PDF plotter, solely because it has the option to use a default filename. I'm in the process of using the built-in DWG to PDF plotter and am trying to auto-populate the PDF filename.
I've found on this forum where people have been able to extract just the filename of the drawing (and not the file extension):
^C^C_setenv DrawingName;$M=$(substr,$(getvar,dwgname),1,$(-,$(strlen,$(getvar,dwgname)),4));
Now, I would like to know how I can insert the extracted filename to automatically name the PDF.
Thanks in advance, and apologies if this has been discussed and I've not found the solution yet,
David Hassan
IP Illustration
www.ipillustration.com
IP Illustration
