Solved by pendean. Go to Solution.
My method is: pick the desired radius for the fillet -> offset each arc by that distance -> draw a circle from the intersection of those two points with a radius equal to the desired fillet radius -> trim away.
This is an older post so I'm not to sure the OP will come back to this thread.
But THANKS for sharing what worked for you.
Ik this is old but for anyone lost on this like I was and googled it, I realized you have to click on the RADIUS title in the COMMAND bar and set the radius BEFORE you select what you want to fillet.
