Using DXFOUT command is shifting the drawing at right side in output dxf drawing
I use dxfout command and select object by clicking on TOOLS->Select Object and I save it in R12/L2 format. But whenever I use this command the coordinates in dxf saved drawing are not same as the main drawing form  which I selected objects. Suppose I have drawn a circle at 0,0 and dxfout and select that circle as R12 dxf file. When I open that dxf file the circle which was at 0,0 is not their anymore. It will be at 8,0 or something like It gets shifted to right side from original coordinate
pendean
Community Legend
Community Legend
I am not able to replicate your issue in LT2019-2020-2021 in a blank new file or any of my own DWG files: can you post a before and after example please (DWG and DXF)?
