Can I update a dimension entity so that it will match a newly and different inserted dimension style. I'm sure the answer is yes but how do I do it? Is there an update command? Thanks
Solved by jarives. Go to Solution.
Solved by pendean. Go to Solution.
Have I posed the question wrong? When I open an existing drawing that I want to update, I open the dimension style menu. I edit the one I want to change (mainly the text offset distance above dimension line) and then type "make current". I execute a dimension to verify that the changes I made work. Then what do you do. I close the drawing and reopen it thinking that all the existing old dimension styles will now appear with per the new edited setting. But they are the same as before. Can anybody explain to me what I am doing wrong? Thanks
Thanks so much for throwing that stuff back on me. I was really getting frustrated running into brick walls. At your suggestion I looked at the menu laid out when you click the Dimensioning tab on the upper ribbon. Then right there in plain daylight at the near bottom or listing was "Update". That exactly what I needed. It was so simple. Anyway thanks for the reply on a late Sunday afternoon. I make that Monday deadline after all.
