Hi
I am trying to update the revision block on multiple sheets without having to do each sheet manually. Is there a way of doing this update on mass being that the same information is needing to be updated.
Sam
Solved by john.vellek. Go to Solution.
Solved by h_s_walker. Go to Solution.
Welcome to the Forums
Find / Replace will do the job, and if you just click on find and the list results (see image below) you can select all the revisions changes on their own. I've only ticked the list box just in case there are similar details
eg
Doing a find and replace on "PROJ" and changing it to "BANANA" will find anything starting with PROJ including PROJ, PROJECTTop, PROJECT2nd, PROJECT3RD, PROJECT and they will become BANANA, BANANAECTTop, BANANAECT2nd, BANANAECT3RD, BANANAECT
Howard Walker
Hi @Anonymous,
Most customers perform this kind of action using Fields that link wither to a SheetSet property or to Drawing Properties. Another popular option is to Xref in such shared titleblock information so you only have to edit it once. Are you willing to share a sample file that shows me how your drawing is set up? Perhaps I can mock up these methods for you to see if that helps your workflow.
Hi John
If you could help that would be great. Find attached the file that I am working on.
Sam
Hi @sam.lewis,
I mocked up a sample Sheet set. I made a video that shows how you can add custom properties that are for the entire sheet set or just the individual sheet.
I linked these properties to fields in the titleblock so you can see how they can easily be edited in the properties of the sheet or sheet set instead of at an attribute level.
Putting your drawings into a sheet set also allows easy PUBLISH and Sheet Index creation. I hope this gets you started.
Hi John
Thanks so much for your help so far. Do you know if AutoCAD LT 2018 has the same functions as you have shown.
Hi @Anonymous,
Yes, everything I showed you and provided in your file should work with AutoCAD LT 2018. The custom properties I created are obviously unique to your workflow so yes, you need to create such properties for your sheetset so you can link the fields to them. I suggest practicing on something small like a small sketch/design project to practice the steps and explore the capabilities. If you decide that the sheetset is too much to handle you can also do very similar linking to fields using DWGPROPS but I feel that it will not provide all the tools you really want.
Hi john.vellek,
I have a sheet set with 600 drawings , 2 kinds of revisions : 00 and 01
How can I update sheet set properties - revision at once time ?
I mean if the client want to change revision 01 to 02 and I can't change revision manual one by one drawing.
I also need to show a list which drawing has a revision. Do you have any idea about this ?
Thank you.
Hi @john.vellek ,
does this video have audio please? I see the mute icon, but it's not allowing me to turn it off.
I have the same situation with a client. There's one particular drawing, with 177 sheets mind you, and they're asking for an easier way to update the revisions across all sheets. Unfortunately the way their client has set up the attribute dialog box makes it really difficult to update. I suggested a script, but they would be happier with xref or what you're doing in the video.
@wanda.keightley wrote:...does this video have audio please? I see the mute icon, but it's not allowing me to turn it off...
There is no audio. Sorry. An the author is not longer around. What do you think you've missed from it that you need assistance with?
Do you/your client actually use SSM (Sheet Set Manager) for those 177 layouts? If not, do they want to adopt it and the learning curve it takes to replace all those attributes they want to edit now?
Would the other tip of FIND and REPLACE work instead? That cannot be automated in a script, your client might be able to find and use a LISP or more in a websearch if they have full AutoCAD or LT2024/LT2025 (no older LT).
Let us know.
