uninstalling old versions
Is it okay to uninstall older versions of autocad LT if the current version is installed
Accepted solutions (3)
jeffrey.sin
Hi @Anonymous,
Welcome to the Community.
It's fine to uninstall the older versions of AutoCAD LT if the current version is already installed. At the same time, having said that, it is not necessary to uninstall older versions of the software when the current version is already installed. You may refer to this link for more information: Do you need to uninstall older versions of AutoCAD before installing a new version?
Let us know if you have any further questions. Thank you.
Jeffrey Sin
Autodesk Customer Support
Emmsleys
If you are certain that you will no longer need the older releases there shouldn't be an issue with you uninstalling the applications you will no longer use.
Feel free to post back in this thread, should you run into a problem.
Sarah Emmsley
Technical Support Specialist
Emmsleys
Also,  select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Thanks a lot!
Thanks Sarah!
Thanks for the response. The only reason I would like to uninstall older versions is to ensure I do not have security vulnerability on my PC. I note a lot of security updates and am trying to avoid disaster from these older versions that may not be as up to date as the current version. I have versions on my PC from 2015 on.
Mike Stevens
