- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good evening everyone,
This is my first ever question on here, so hopefully this isn't too green!
After a good long day of tweaking my new custom title blocks, I decided to automate my title blocks somewhat using fields and certain custom properties- this has been a great time-saver and certainly makes you feel slick when you regen it 😉
My question here is I have a an MTEXT field that syncs with my drawing title within the properties box and, as expected, it wraps when the string gets too long per line. No problem.
The trouble is when I have a client address that is shorter, it'd be nice from a formatting point of view to be able to put line breaks in so that the street address is on top, the municipality the second, province, the third and so on. Normally when I edit MTEXT, a simple SHIFT+ENTER works just fine, but I'm editing this field from the Drawing Properties dialog, so the text stays in a single line. The other problem is that my MTEXT is nested into a title block which I thought would make my life easier, but not so much here. Because of this nature, I cannot select the MTEXT without block editing and that.. sort of defeats what I was trying to do (especially if it becomes necessary for each project).
I know you can use some short hands to place symbols (*.shx substitutions) for centre-lines, diameters, superscripts and so on (and oddly enough a non-line breaking space), but is there an equivalent that ACAD recognizes for a line-breaking space? I did some digging and apparently windows natively recognizes \U+2424 as a line-break, but ACAD can't render it 😞
If anyone has a neat trick they'd like to share, that'd be great! I'd hate to have to put a number of spaces to force the line break. I also suppose I could live with this if it doesn't work.
Thank you all in advance for taking the time! 🙂
Cory, the curious.
