New to ACADLT and wondering if there is a tolerance setting that would prohibit a complete connection when trying to connect tangent points etc. Hatch shows disconnects that appear to be connected.
Solved by bvld250. Go to Solution.
Is zero a staring point. Am having similar trouble with objects not connecting to snaps, and bouncing around the intended intersection
Boundaries still do not connect after numerous regens, snap connections, and a cut and paste to a new file. see clip below:
