Message 1 of 14
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Drew a plot with degrees and direction for a property. Then wanted to rotate the ucs so the drawing was pointing north and squared. I have attached 2 screenshots. After rotated it the lines werent straight looking and the lines appear now solid rather than broken lines(for property lines). I also rotated it in the model space. I may not be doing it correctly. After i drew the plot i typed the usc command and then selected object and put the x,y axis on the bottom left corner. Then i typed plan and set to current ucs. Should the ortho button be on? Also do i separately rotate the notes (seen in the botton left of the screenshot - after the rotation?
Thank you for your help
Mary M.
