Here's an utterly bizarre problem. My boss and I are both running LT2020. On his machine he has a semi-regular issue, where when he tries to insert some MTEXT, the UCS rotates around the Z axis, effectively making his crosshair disappear. Looking back through the command line shows NO UCS command! He has to reset the UCS to World to continue.
Any ideas?
Hi @Anonymous,
Thank you for posting your question here on the Forums! I just wanted to check in and see if the solution that @pendean provided helped resolve the issue?
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
