- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, so I sent some DWGs to someone and they said that when they opened them "everything displayed as black, all the lines were black" that they were having trouble viewing them (some lines are meant to be in color). They said they think it's because my DWGs are using True Color instead of Index colors and that sometimes "AutoCAD has trouble opening True Color", that for now they would manually change the colors in the Layer Properties manager from True Colors to Index Colors, e.g. True Color 0,0,0 Black to Index Color Black #250. I'm using AutoCAD LT 2021 and exported the files as 2018 .DWGs. They said they also have AutoCAD 2021 but that they also use AutoCAD 2013, they tried to open the files in AutoCAD 2021 but said what I stated above. They requested 2013/2010 .DWGs so I exported my files as such and sent them to them. But they said the 2010/2013 DWGs were having the same problem.
My question is basically if anyone knows why they could be having these problems with the colors in the files I sent them? Is it a compatibility issue? Does AutoCAD 2013 support True Color? Is it true AutoCAD sometimes has trouble opening True Color and Color Books? I've only been using AutoCAD for a few years so I'm still learning. Thank you.
Also I'll attach one of the files, in it's 2018 .DWG format and 2013 .DWG format so you guys can have a look.
