Trouble with Dimension Orientation
Message 1 of 8
Can anyone tell me how to get my associative angular dimensions to display 56 degrees in this case (shown in picture) instead of the 34?
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Can you post your actual DWG file? Your 34.4 sure looks very similar to the 30.1 you have right next to it, and we both know neither is close to 56.
TIA
Message 3 of 8
Please see attached
Message 4 of 8
RobDraw
Draw it at the correct angle?
Rob
Message 5 of 8
pendean
Community Legend
Community Legend
Not seeing anything wrong in your posted file here
Message 6 of 8
In that same drawing. Start a new horizontal line, from say.....the mid point of that line type in @6"<56 and see where it throws the line. Then do an angular dimension on the two lines and see what it says...............
It's almost like the 34 and 56 degrees are reversed when dimensoining
Message 7 of 8
pendean
Community Legend
Community Legend
Set SNAPANG command to 34
Compare your cursor angle to your angled line.
It matches.
34+56=90
56 is the reverse of 34: see the 56 angle to the left of the 34 angle. Get it?
No idea what you selected when you did the original screenshot, but facts are in the CAD file. I cannot repeat here.
HTH
Message 8 of 8
I'll give it a try, thanks
