style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"alb" <Is
href="mailto:andybarnes@gspfareham.co.uk">andybarnes@gspfareham.co.uk>
wrote in message
href="news:f1a4ba9.-1@WebX.maYIadrTaRb">news:f1a4ba9.-1@WebX.maYIadrTaRb...
it possible to extend or trim several lines at once? ie. by selecting one line
to extend to and then exending several lines without having to click on each
one. I am sure there use to be such a command but can't seem to figure this
one out.
Thanks in advance
Andy
The command FENCE does not seem to mean anything.
Thanks AUTOCAD for keeping these forums so organized! It's extremely helpful and I just LOVE wasting time!
I think what the above comment may be referring to is a step by step explanation of how to extend multiple lines simultaneously :
1. Enter command ...?
2. Within this command type or click on ...? (if I click on something, where is it located)
Can you provide this information?
The solution explains it clearly. If you need more information, try using help for such simple things. Autodesk has provided it in an organized manner.
It is useful. It's exactly what the OP asked for.
Hi, this maybe can help you, just load LengthenTotalMid.lsp into Autocad, type LTM, enter length, select objects, enter.
I want to use a command or shortcut to trim extend or fillet all lines at the same time is this command available in CAD?
TRIM and EXTEND commands require you to select the items, which you can do not just individually but in a group with the FENCE selection method.
If you are asking to just press a button and the program guess at which lines to trim on its own, it does not do that.
