Transparency keeps defaulting back to 0% when i close a drawing
ANDREW.ROBBBAG6A
ANDREW.ROBBBAG6A
hi,
In AutoCAD 2023 LT I colour hatches to a 50% transparency, but when i close and reopen the drawing the tranparecy has defaulted back to 0%.
it was never an issue in 2022 and takes a bit of time (thankfully the select similar command is very effective)
any hints/tricks gratefully received.
Transparency shown as zero, how do i make it stay as 50%?Transparency shown as zero, how do i make it stay as 50%?set
Replies (18)
imadHabash
It seems that you're in layout tab .. we need to check your case .. would you please attache here any CAD dwg sample for testing ?
Imad Habash
ben.saa
Autodesk Support
Autodesk Support
It'll be much easier to test on a sample file I agree with Imad
ANDREW.ROBBBAG6A
HI, thanks for the interest. I don't think there is much to be gleamed from me uploading an example but i have done so. I thought it may be a hatch setting so double checked in the hatch dialog box which was set to 50% as well as the properties.
Closed it down, opened back up and the hatch has returned to 0% transparency.
Any ideas greatly welcomed.
h_s_walker
Is your version of LT fully updated?
Your example drawing keeps it's transparency at least in LT2016
Howard Walker
Left Handed and Proud
ANDREW.ROBBBAG6A
Hi, yes checked that yesterday in case it was a glitch.
pendean
Community Legend
Community Legend
Well, you have this set
And this set
So... what exactly are you changing/doing so we can follow along? When I do this it sticks after saving, closing and opening your file
And when I do this it sticks after saving, closing and reopening your file
LT2023 in Win10Pro here
ANDREW.ROBBBAG6A
So I am changing the Properties, then 'General' then 'Transparency'(changed from layer to 50%) as well as changing the actual hatch to 50% transparency when I am in it.
Sounds like yours is working(as mine did in 2022 Lt), I am windows 10 as well........
ANDREW.ROBBBAG6A
hi, thanks....I am doing what you have (very helpfully) illustrated....but i am getting a different result unfortunately. Randomly the changes don't 'stick' when I do them.
pendean
Community Legend
Community Legend
Test the two files I included.
if you are still having issues then you will need to engage Autodesk Support: start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
laurie.nichol
I also have an issue of transparency changes "not sticking" after I've applied them.  Infuriating.  Typically with blocks, but lately with linework too.  Have you found a solution in the time since this query was posted?
marcuspinto2HWZ8
Man, i had the same problem and i discovered that my "Open and Save" configuration was on a previous version that didnt support the changing of transparency outside of the layer. I solved just changing the format of save the file from "AutoCad L14/LT98/LT97 Drawing . dwg" to "AutoCad 2018 Drawing . dwg".
ANDREW.ROBBBAG6A
Thats super thanks, just off to try it.
_Zaphod_
Ignore all the suggestions given previously.  Set the variable CETRANSPARENCY to "ByLayer".  I was having the same issue as you (in my case, every time I edited blocks the hatch objects reset from ByLayer to 0% transparency) and changing this variable fixed the problem. Note that this is not a global system variable - it's per drawing.
ANDREW.ROBBBAG6A
Brilliant, thanks - i actually gave up but that advice actually works thanks.
pendean
Community Legend
Community Legend
@_Zaphod_
"CEP variables are used to control your current active setting, in other words, they are used to set the default to always be that as they draw. If that was the fix for you, the trigger was you choosing to change the default you draw all the time. Consider using SYSVARMONITOR to help remind you that these important default settings where changed and that you need to set them back.
Look up the full list in HELP, here they are: CECOLOR, CELTSCALE, CELTYPE, CETRANSPARENCY and CELWEIGHT.
MSchille-1994
I am experiencing the same thing and my CETRANSPARENCY is set to -1 (bylayer).  Everytime I reopen the drawing the transparency of the hatch is set to 0.  I set it to bylayer and save it, reopen it and back to 0.
Attitude, not Aptitude, Determines Altitude
cadffm
Sounds you are saving in a very old drawing format, what does know nothing about transparency.
But one thing is odd:
What have cetransprancy to do with a existing drawing object?
Or do you ralking about the setting for new hatchs?
Saveas dwg2018 and try it again.
Sebastian
pendean
Community Legend
Community Legend
@MSchille-1994 Modern versions of LT (and all variants and versions of AutoCAD) allow for a startup LISP to preset this and any other settings to want to be anything you want every single time you open a DWG file. So you can just implement that.
OR... start SYSVARMONITOR command, and the CETRANSPARENCY variable setting to that watched list, as well as all other variables you wish to be just so, and use that tool to reset it/them when it notices they changed.
How would you like to proceed? You are in control.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
