Tool Palettes
Tool Palettes
mhotwani
Tool Palettes
mhotwani
I have yellow thunderstorm like symbol. Unable to drag and drop blocks on to drawing.
Need assistance please
pendean
Community Legend
Community Legend
The icon simply means those are DYNAMIC BLOCKS, nothing more.
Do you perhaps need to turn on/thaw all of the layers in your file to see them when you slide them into your drawing?
mhotwani
Thanks for info, It partially worked with few, but others not able to drag and drop. I am going to keep experimenting but its a pain!.
I have also brought and re-attached the path within file location in options. But nothing, it only has happened when Auto Cad updated from 2020 to 2021.
Thanks for help.
cadffm
That has nothing to do with the thunderstorm like symbol,
and if I am right, you git a message from Acad if you try to insert the block, or not?
Try to insert one of the issue-blocks,
press [F2] and share the last lines with us.
>>" but others not able to drag and drop. "
Is there not a strange cursor symbol? And  no message from Acad[F2]?
Please try to CLICK instead of drag&drop. Same problem?
>>"I have also brought and re-attached the path within file location in options. "
Thjat has n othing to do with the insert-tool of your toolpalette,
RIGHT-click on the tool, properties, check out the path and blockname there!
>>"But nothing, it only has happened when Auto Cad updated from 2020 to 2021."
If the block is present in the location (blockname, filename, filepath) it should work.
Sebastian
