AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
The Ribbon does not habe any tabs or panels currently loaded.
9 REPLIES 9
Message 1 of 10
3264 Views, 9 Replies
I accidently deleted my menuload ACADLT.cuix and my AUTODESKSEEK.cuix i found and reloaded them and now my Ribbon is gone. If if type ribbon in the command line "The Ribbon does not habe any tabs or panels currently loaded." appears.
Help PLEASE im at work and need to get this resolved ASAP
9 REPLIES 9
Message 2 of 10
pendean
reinstall LT is one option
Message 3 of 10
Charles_Shade
in reply to: pendean
Or click on the Workspace in the Left pane of the CUI, then Customize Workspace on the right side of the CUI.
Then expand your Ribbon Tab in the left pane and make sure they are checked.
Then stand on one foot and hop up and down whilst rubbing your belly...
Message 4 of 10
I did reinstall same thing
Message 5 of 10
in reply to: Charles_Shade
They do appear in the cui
and I also reinstalled the software i dont know what to do now
Message 6 of 10
Charles_Shade
Did you go to Customize Workspace and check the Panels you want on the left side of the pane?
Message 7 of 10
I went into workspaces and then edited on the right side adding all of the tabs under ribbon and then hit done and apply then closed cad and restarted and still nothing. Now what 😞
Message 8 of 10
Charles_Shade
Post some screenshots of your CUI (expanded, several different) and Workspace so we can take a look.
Were you able to get to the view that I posted above?
Have you tried another Workspace perhaps to see what is there?
The reinstall may need to be a clean install if needed to do again:
Remove Autodesk Products:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Message 9 of 10
Crass
Has anyone found a solution to this?
I have this same issue. Its a major problem. Is there any quick fix? I have a deadline and really do not want to reinstall LT right now.
AutoCAD 2018/2021
AutoCAD Civil 3D 2021
Tags (2)
Message 10 of 10
Charles_Shade
in reply to: Crass
Expand the Workspaces Tree
Right click on your Workspace
Choose Customize Workspace
Expand the tree of the main Ribbon and the Ribbon tree of your Partial CUI File
Are the Ribbons you want checked or otherwise highlighted?
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Technology Administrators
