Texting commands
Texting commands
Texting commands
During my latest session I had troubles changing the size of the text while adding dimensions
to the drawing. Working in paper space, I made several attempts whithout success. I work in the dimension style "bygg" =Swedish for build; it´s an architectural drawing.
Eventually it all ended up with the two buttons "Single line" text  and "Multi line" text having disappeared from their place to the left on the  Annotative bar.
So now I can't even add common text lines.
h_s_walker
Can you post an image of your problem. That will help us see what is happening.
Howard Walker
Left Handed and Proud
pendean
Community Legend
Community Legend
Are the text sizes hardcoded in STYLE command?
Are you using annotative Text and Dim styles by chance? Or maybe you should be?
Here´s a photo of my current drawing. When I started originally, I had the buttons Single line text and Multiline text to the far left on the ribbon.
pendean
Community Legend
Community Legend
Do you just need to reset your AutoCADLT to regain all the missing menu items? Here is how you do that https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Thanks ,the solution is always closer than you Think.
Since the reset to default mode, a new problem occured: although I have done this several times in older AutoCAD version, I can´t find the command to change the paper space/ sheet backgound to dark. The model area is dark.
steven-g
the command is Options, pick the display tab - window elements color scheme, or colors
