how do i prevent my autocad 2020 from creating acad lsp files?
Message 1 of 9
Is there a way to disable the automatic loading of acad lsp files in autocad 2020? This file recently been detected by our AV.
Replies (8)
Message 2 of 9
vinodkl
Can you share the screenshot of what is happening?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 9
Thanks for prompt reply. There is no error to be screenshot sir, the problem is everytime this lsp file created our AV detect it as a virus. So i just came up to a solution of preventing this file to solve the issue.
Message 4 of 9
vinodkl
Are you creating you own lisp, and the AV is detecting them as virus and blocking them? If yes then you need to exclude the particular files from being detecting by AV.
You could also read this: AutoCAD, Viruses, and Security
Message 5 of 9
steven-g
This is the LT forum, LT is not capable of using Lisp although your question isn't directly about Lispit would still be better served in the dedicated forum where it is less confusing for the community 🤔
Message 6 of 9
No sir. this acaddoc.lsp files are loading automatically everytime cad file open,and  this files are being define as virus by our AV.
Message 7 of 9
Hi sir. this is autocad LT 2020, apology, i already corrected the title. Anyways, this acaddoc.lsp file are being automatically generated (on the folder where cad located) every time cad open. This files are being detected as virus by our AV (sophos)
Message 8 of 9
steven-g
Where is this file being found, which folder on your system? There are several posts about an actual virus using that name. So your AV is doing its job well, but these aren't created by AutoCAD. It does sound as though you have a problem that your AV should be dealing with.
Message 9 of 9
pendean
Community Legend
Community Legend
Post a screenshot of your ABOUT command pop-up please.
Also read this and send an email to the address at the bottom of the page to report your issue https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/AutoCAD-...
