TEXT to MTEXT in LT; Is it possible
Message 1 of 16
Is it possible to convert single lines of text into an MTEXT entity?
Replies (15)
Message 2 of 16
Sorry, not automatically like in full AutoCAD's TXT2MTXT Express Tool
command.
You can, however, copy each line individually and paste them into an
MTEXT session. Or, better yet, copy the single line text and paste into
Notepad, etc, and then select all lines at once and paste into the MTEXT
editor.
Bob Felton
Autodesk Product Support, Platform Technology Group
Message 3 of 16
^C^C_-mtext;\@;NEW 1/4" DENS DECK;MECH.
FASTENED;;
Here's an example of how I might change a single
line text to a Mtext.
1.  I copy a single line text into the above
macro and then I'm able to make corrections to the text as if it were Mtext,
which it is.
Is
entity?
Message 4 of 16
qtarchitect
I can not paste the line text from CAD into notepad. Sorry
Please help
Message 5 of 16
qtarchitect
I could not paste a single line text into a mtext session.
Please help
Message 6 of 16
pendean
Community Legend
Community Legend
You need to copy/paste from inside each of the text editors: simply selecting a text object is not correct.
Message 7 of 16
qtarchitect
Thank you, I finally figured it out right before you sent the help note email.
I still hope there are ways to select a bunch (sorry for lack of words) of single text lines and convert them into a mtext like we have on TXT2MTXT.
And I realized there are no lsp and/ or macro, I suppose.
(I am just an one man operation architect office, I bought LT version and can not afford to buy a full version)
Message 8 of 16
pendean
Community Legend
Community Legend
I wish it was a core command as well 😞
Message 9 of 16
qtarchitect
Hope Autocad will make it work for LT with an update/ service pack in the future.
Message 10 of 16
ekgsrcivic
Observer
Observer
You can also (easiest way) just double click you plain Text in acad, copy the contents and exit text editor, then simply right click paste anywhere in acad and it will paste in as Mtext. Thats what I do. cheers
Message 11 of 16
Emmsleys
Thanks for sharing that suggested workaround!
Sarah Emmsley
Technical Support Specialist
Message 12 of 16
Emmsleys
To add here are a few resources links that might help provide a different perspective:
Convert Text to Mtext in LT
Tutorials:Convert text to Mtext and vice versa (full AutoCAD)
Sarah Emmsley
Message 13 of 16
Not sure what everyone here is talking about.
You absolutely can do this.
One of the updates about 6 months ago to ACAD LT was the TXT2MTXT command which now works great in LT.  In fact seems to me to work just like the full version.
Just update your version of LT with the patches and it will work.  If you choose SEttings, you can select how the command deals with the text - single line text to single line mtext, single lines of text to a single mtext piece, maintain line spacing, etc.
Very simple to use once you install it.
FYI... LT does do LISP and other stuff - when ADesk allows it to for their own purposes such as this or with a 3rd party plug-in, of which there are a couple out there.  ( http://www.cadsta.com/CADSTA-Tools-Appload.html )
Message 14 of 16
pendean
Community Legend
Community Legend
>>>... months ago to ACAD LT was the TXT2MTXT command which now works great in LT...<<<
This is for LT2017 only, and only if you have access to the Fall Update patch under your active Subscription Updates page. It should show up in LT2018 as a core command/feature later this spring when it is released.
Message 15 of 16
Emmsleys
Thank you for providing the information about the newer AutoCAD LT features.
But to add this thread did initially start in 2002.
I am sure other user's who come across this post and thread who have similar questions will find this post helpful.
Resources:
AutoCAD LT 2017: TXT2MTXT (Command)
Sarah Emmsley
Message 16 of 16
Emmsleys
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
