I am trialing AutoCAD and everytime I type in text in will not permanently stay on the page.
1. I type and press enter and a second line is initiated. I press enter a second time and the text disappears.
2. I type and then place my cursor in a new position and a new text opportunity is provided. I type a second entry and place my cursor in a new position and again, a new text opportunity is provided. If I then press Enter, the text disappears.
I've not come across instructions that divert from the above method, so not sure what, if anything, I'm missing.
Thanks for the direction; I checked the layer, turned it off and back on and repeated above procedures and still no text remains.
TEXT oe MTEXT?
Annotative or Non?
STYLE definition for text size and font? and by chance is your text height like 1" and you are about 10miles away from it, for example?
He's apparently using DTEXT 'cause AFAIK that is the only text that behaves that way. type a line ... press enter ... press enter again to end the command.
Doesn't solve his issue but at least it puts more light on the problem.
DJ
I type in 'text' in the command line and the next prompt asks for the insert point/coordinates, followed by prompting for angle, which I accept as 0. It then opens a dotted dialog box which I type into. When I start typing the text is displayed as a standard 'large' size. Great thought about the size/height; I will check that out. Unfortunately I am out of town today with the autocad computer stationary at the workplace, but will check out your suggestion first thing tomorrow...thank you pendean!
I am currently updating a dwg file with blocks in the model. For some reason the text from the orginal drawing is not appearing in model space or paper space. I then check the layers to see if anything is frozen, turned off, locked, or not visible. After messing with all of the layers in the entire model the text is still not appearing. I then created a new layer, named it text and start to type. Disapears again.... What is going?
Ok perfect! I typed in STYLE and realized the SHX file was not to be found. I simply chose another text that did not have a yellow triangle of dealth and the font appeared. Thank you!
Another thing i found helpful when my text was disappearing is to make sure that Show annotation objects is set to always. This should keep your text from "Disappearing".
I'm a newbie as well and it might be something as simple as the mistake I made.
Text kept on disappearing every time I saved in model or paper space. I was using the default settings with a black background.
My text colour was set to white for some reason. This means that in model space the text is actually black, in paper space it's white, so it's there you just can't see it. I set it to black and revealed about 10 copies of the text.
Easily made mistake for a student.
