Text disappears after using block editior to edit a title block
phas50
Message 1 of 8
phas50
I create a matrix to add to a title block, I add text to it in block editor but the text does not show in the title block after I close block editor. I checked my layers, they are all on, not frozen or locked. I have never experienced this. I am using AutoCAD LT 2017.
Need help urgently.
Peter
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Did you add text or attributes?
Are they set to show if attributes? They can be set to hidden too.
Message 3 of 8
phas50
In the block editor I added text, when I close the block editor and insert
the Tblock my text are not visible. When i open block editor I see the
text. Where do I find the attributes for the text since I never added any.
Thank you in advance.
Peter
Message 4 of 8
pendean
Community Legend
Community Legend
Any chance you can post that DWG file here? Point to the block with text please.
Message 5 of 8
phas50
Thank you for you help.
Message 6 of 8
pendean
Community Legend
Community Legend
Nothing posted if you meant to do so: if you have dropbox or google drive or one drive you can share the file here that way.
Message 7 of 8
Emmsleys
Hi @phas50
Are you able to share a file of your drawing?
To add:
Try looking to this link.
Sarah Emmsley
Technical Support Specialist
Message 8 of 8
phas50
I tried doing so. I solved the problem without knowing the reason for the problem. I exploded the title block, created a new block using the same title block, gave it a new name and it worked. What I did not understand was the fact that I was seeing my text in the block editor but as soon as I closed it they disappeared. I do not know if the fact that the Dwgs were created by 2010 cad and I am using 2017 LT. Christopher Columbus meeting Elon Musk I guess.
