- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I was wondering if someone could explain temporary override keyboard shortcuts to me. My expierence is that it viaries when it works and not. Holding 'Shift' for the toggle ortho mode works fine, but for example: I am in the command "Line" (I have tried it with and without selecting the first point) and I will use Shift+A ,which should be 'Object Snap Override : Endpoint', sometimes it works and sometimes it does not. I can not get a clear idea as to when it works. The same goes for all the other override shortcuts. I use AutoCAD LT 2024.
