Message 1 of 16
Suddenly Cannot Move Dimension Text Alone
06:44 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Howdy. I am using AutoCad LT 2011, and I have been having this problem with this and other versions for years. Suddenly and for no reason, it becomes impossible to move dimension text alone. I have searched the net numerous times for an answer to this problem, with no success. All I ever find are the usual help files stating "It is possible to move dimension text alone". That is not entirely true, or I would not be posting here. 😉 I can have a drawing with multiple dimensions.....and some of the dimensions I can move dim text by itself, some I cannot. I have tried to copy the properties from a dimension where I can, to a dimension where I cannot, and it changes nothing. I have gone through every conceivable setting in the Dimension Style Format, I have compared the properties of one dimension where I can move the text by itself, and one dimension where I cannot, and found no difference. Above all, I have no idea why it happens to begin with. I can save a dwg, come back to it and everything is fine, then I can come back to it again later, and I will be no longer able to move the text of that particular dimension by itself. If I am putting my text to the side of the dimension above the horizontal line, I can always use "Move Text With Leader", and when I get the text close enough, the leader disappears. But if I am keeping the text above the horizontal dimension line in the center, I cannot use that feature because the leader will not go away. The only way I can fix the problem is to delete the dimension, and put a new one there. And eventually, I will be unable to move the text by itself on that dimension as well. All I want is to be able to create a dimension, and have the text movable by itself permanently with no change, forever, and ever, amen. It is not a major problem, just aggravating to say the least. 😉 Any help anyone can provide would be much appreciated. Thanks in advance. Have a nice day everybody.
