AutoCAD LT Forum
Stretch pdf graphic
8 REPLIES 8
Message 1 of 9
6772 Views, 8 Replies
Stretch pdf graphic
How do I stretch a pdf graphic in AutoCAD LT 2006? In some of my drawings I can stretch the graphic & others I can't, even if I unlock the aspect ratio. It seems to be a system variable setting that is wrong, but which one?
8 REPLIES 8
Message 2 of 9
Make sure OLEFRAME is on, select the image, unlock the aspect ratio in
Properties, and stretch. If it does not work, it's not an OLE?
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
Message 3 of 9
Thanks for your reply Dean, but it still doesn't work. I've tried it with both jpg & pdf files. OLEFRAME is set to 2 & aspect ratio is unlocked.
Message 4 of 9
Post a sample file... .
Dean Saadallah
Message 5 of 9
Hi Dean,
Thanks for your persistence.
Message 6 of 9
You've got a rotated UCS in your file, and some other issues with the OLE:
is that intentional?
Set UCS to World, reattach and I think your problems will go away.
Dean Saadallah
Message 7 of 9
Thanks Dean, that's done the trick! The rotated UCS was not intentional. It's an old drawing that has been kicking around for a long time.
Message 8 of 9
David125
how do you unlock the aspect ratio?
Message 9 of 9
pendean
in reply to: David125
PROPERTIES palette should have that category in place when you select the pdf/image.
Technology Administrators
