Hi, I am having some issues in models space. I have bathroom floor plan layout and not all lines show up on black screen (shower tray area, right wall hatch, etc). Lines are not black, they are white. I have used many commands such like: Regen, Regenall, Audit, Purge and Recover file. Nothing worked so far. I have copied content to a brand new file, problem still persists. I don't want to select every single object/line and change the display order bringing it to front. It's too time consuming. Would you possible know what is causing this problem and how to sort it out but just using one command and doing it in one go instead? I will much appreciate the answer. The file is attached. cheers
